Noise while acclerating or turning on the A/C
Old 08-25-2010, 09:28 AM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
So recently I have been hearing this noise coming from under the hood on the passenger side. I just started hearing it when I start my car but I noticed it does it when I turn the A/C on and when I acclerate slowly like going up in a driveway. I wish I had a video so I could show you guys the noise but hopefully someone knows what im talking about ...
Also has anyone had the problem when turning off there defroster when its on 60 after you turn it off sounds like a rock hitting behind the A/C controls...
Old 08-25-2010, 09:54 AM
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
thelastaspec's Avatar
Both of my parents Fords do this. It has to do with the valve that controls the referigerant/temp in my case, It has been doing it on an off since day one - it's a feature to know that the truck's ac has accepted what your saying - jk
I forget what the valves called.
The "connection" to the blower motor is also prone to overheat and fail, its located underneath the glovebox.
>If you hold the "Auto" and "Off" buttons for ~1min (with the car on II)the HVAC systec does a self check, and will light a section of the lcd if domething has failed.
Old 08-25-2010, 10:24 AM
-TL Love-
TL3.2000's Avatar
i think the owners manual says something about that noise in the AC section
Old 08-25-2010, 10:28 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
likely noise suspects under ac load-
ac belt tensioner pulley, located at top of engine behind the alternator,cant miss it!
Use a mechanics stethascope or long screwdriver- place tip against NON moving base of unit, listen for neighbor kids garage rock band type sounds--whirring and thunking, bad rythym
compare to good turning objects- with slight whir but smooth sound to it
thats the bearing shot in the tensioner- very common, got mine done at 80kmiles- had been noisy since 45 and got really bad,,aftermaket $85-100 part for complete unit
can do the listen test (stethascope much preferred $4 Harbor freight tools 5-10 part stores )
to ac compressor, ps pump, anything that moves and has a solid point you can place the tip on
Listening to valves will tell if one or more are making a different noise than the rest- means needs adjustment
Old 08-25-2010, 10:34 AM
01tl4tl's Avatar
ck the cabin air filter condition- just go ahead and replace it if not done in the last 12 months
ck the wire connector unit to the blower motor- a short wire makes it tight fit and many have the prob of connector MELTING and possibly buring the plastic
acura makes an update `blower motor wire kit`- less than 20 bucks, longer wires new connector, splices in easy
the other noise may be the doors in the vent system-
it helps to turn the fan down to 1 when changing where the air is going- less strain on a tiny motor moving a plastic panel and springs that at level 5 blaster air speed
Old 08-25-2010, 10:39 AM
01tl4tl's Avatar
note to all-
keep that small vent in the rear of center console/armrest/storage bin
OPEN at all times--
the one for rear passengers- Open rear door and look if you dont know about it
you cant stop the air from pumping there and gets blocked up in there- escaping thru the leak in plastic sleeve fitting-- freezing or heating your console stored items/cd's, and temp changing the cup holders
Open the vent and the air has somewhere to go
also cuts down mildew mold potential in the vent
Old 08-25-2010, 01:09 PM
Flipster23's Avatar
k i will check all of those things
because that noise is getting annoying esp when I park downstairs in the garage at work all you hear is that noise since everything is enclosed
Old 08-25-2010, 06:48 PM
01tl4tl's Avatar
mine got so bad the neighbors would look at it!
its final days were loud enough to let you know: the time is now
Old 08-26-2010, 11:39 PM
Flipster23's Avatar
going to try and go get the part 2morro see if the stealership will hook me up : sometimes they do
Old 08-29-2010, 09:36 PM
mnjeepmale's Avatar
I have noticed something that has happen about 4-5 times over the past 4-5 weeks. When I turn on the A/C after I startup the car I hear a loud screech and bang from under the hood. It only happens when I turn on the A/C. I have replaced the belts and just recently the belt tensioner thinking that was the problem. Could it be that the compressor is starting to go out?
Old 08-30-2010, 11:34 AM
01tl4tl's Avatar
get a $5 mechanics stethascope at parts store- start probing the compressor for bearing noises - ck the replaced tensioner--even new parts fail
replaced the ps belt too? if its set too tight many problems occur
Old 09-01-2010, 12:26 AM
Flipster23's Avatar
checked out bought one of those mechanic stehtascopes (those come in handy) so anyway listened to it... Sounded like a bad bearing inside the A/C pulley went to the stealership and they said I have to get the whole new clutch system 206 bucks I said hmmmm I'll come back
Old 09-01-2010, 01:16 AM
01tl4tl's Avatar
ck with an ac repair shop, call a few parts stores, use the internet to find one aftermarket
bearing in ac pulley--you mean belt tensioner or ac compressor has issue in its clutch?
Old 09-01-2010, 08:50 AM
Flipster23's Avatar
yea so they said I have to replace the whole clutch but I think im just going to start with the tensioner to see if that works since its cheaper
Old 09-01-2010, 11:16 AM
01tl4tl's Avatar
if its the compressor clutch there is no getting around it
did the tensioner make bad noises in the stethascope?- you can easily tell if its bad or not,,smooth sound or grinding whirring
compare to other bearings
go ask an ac shop about new/rebuilt whole compressor vs fixing yours
System will need a vac and refill after install of compressor
02-25-2020 09:57 AM
01CLOwner
10-09-2015 01:07 PM
2012wagon
09-29-2015 04:21 PM
theinsvnity
09-10-2015 10:22 PM
dlknight
09-03-2015 07:54 PM
Quick Reply: Noise while acclerating or turning on the A/C
