Need to Replace My Oil Pan
Old 03-17-2014, 06:26 PM
2nd Gen VTEC's Avatar
The threads on the inside of the pan are stripped, and I used a self threading drain plug that has helped slow the leak, but I really need to put a new oil pan and gasket on there. Does anyone have an idea of where I can have this done, besides the dealer, without going crazy on the price? I'm thinking Pep Boys but I'm a little uneasy about that. Does anyone have any suggestions?
Old 03-17-2014, 06:27 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
or
You could DIY it.. Pretty easy if you know you way around cars.
Old 03-17-2014, 06:32 PM
I wish I could do it myself, but I'm really not that well versed to do an oil pan. A friend of mine is a master bmw tech and he could do it, but I'd rather have it done at a shop and have a warranty on the labor
Originally Posted by Skirmich
or
Old 03-17-2014, 06:44 PM
Skirmich's Avatar
A shop will charge at least 2 hours for that.. more than 4 and its a rip-off.
Old 03-18-2014, 07:32 AM
3.2TLc's Avatar
If ya have a new oil pan installed, the warranty isn't important.
Have ya considered having the present oil pan's drain hole re-sized by drilling/tapping with a steel helicoil insert ?
Old 03-19-2014, 04:37 PM
That's true. I think the labor for one of the local Mr. Tire shops was quoted at $225, so I think they're going to be charging a little over 2 hours. Probably like 2 1/2 hours
Old 03-19-2014, 04:39 PM
I've thought about that, but all of those metal shavings in there would just make me nervous. It would definitely work but I think I would much rather get a new pan
Old 03-19-2014, 05:33 PM
Skirmich's Avatar
It that is your concern get a magnetic plug and the Pick Up screen and Oil Filter will do the rest.. Remember than its Pick Up Screen > Oil Filter > Rest of Engine so those shaves will not see the light of day anywhere near critical engine components... With the Magnetic plug they will get secured until the next oil change.
Old 03-19-2014, 05:36 PM
3.2TLc's Avatar
Yeah, and ya can also use some cheap oil to flush out the pan after the work.
foxriderar77
11-19-2020 10:17 AM
kmarqueling
10-03-2015 01:14 AM
Aleax
09-11-2015 11:31 AM
Allen_442
09-08-2015 06:01 PM
Quick Reply: Need to Replace My Oil Pan
