need help - installing rear struts
Old 09-30-2011, 11:17 PM
Boomer SOONER
ou sig's Avatar
ok guys i am tired and annoyed. I replaced one of my rear struts (will do the other later) and for some reason the top center bolt will NOT stay down when I lower the car and drive. it shoots up like it was not tight at all...since the rears dont really need a spring compressor I just put the spring over the new strut and pushed it all to the top then 1st tightened the 2 14mm bolts that hold it all together to the car body. then I put the bottom 17mm bolt that holds the strut assembly to the car together. then I tightened the top center bolt for a while but it never really got tight...
should I have tightened this bolt BEFORE putting it all on the car?
Old 09-30-2011, 11:45 PM
MechEng
03tLsNBP's Avatar
it sounds like you forgot a washer or spacer or something when you assembled the shock and spring.
i had this same problem when i installed my KYBs and Eibachs. i took it apart, messed around with the setup, but it would still clank around when i drove.
i ultimately solved this problem by getting coilovers
Old 10-01-2011, 01:13 AM
02TL4ATL's Avatar
yea you forgot a washer that goes over the rod to prevent it from going through the top hat
Old 10-01-2011, 02:15 AM
Avant Garde Wheels
jjashaa's Avatar
this should help you on assembly of the shocks.. those washer are important!
most likely left out #2 or #11
Old 10-01-2011, 08:55 AM
Boomer SOONER
ou sig's Avatar
ok thanks for the diagram - last night I was not in the mood to take it all apart again. I know I left off #3 so I will take it all down and look through it again. regarding the #1 washer, do you need to use the stock one or the one that came with the strut? because a bigger, thicker one came with the strut but maybe it was meant to be the #2 washer...?
Old 10-01-2011, 10:46 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
And make sure the rubber bushings (#7) go in the way they are pictured in the diag above and not the tapered way down.
Old 10-02-2011, 07:27 AM
Boomer SOONER
ou sig's Avatar
I left off #2 and #3...thats what I get for being in a rush late Friday. all fixed now
thanks again
02-25-2020 09:57 AM
Heyzuez20
10-14-2015 07:18 AM
EE4Life
09-11-2015 10:13 PM
Quick Reply: need help - installing rear struts
