Navigation works but clock not working
Old 09-06-2016, 03:09 PM
  #41
johnny14's Avatar
Originally Posted by Kozfire2003
My 1999 TL is doing the same 0:00 time thing. I noticed it on 9/2/16, but that was my first time in the car since two week prior. It is obviously a Y2K timeout type situation.
Welcome to the club! Its definitely a software issue and to be honest with you with all the run around I was getting with Acura and the Navigation support it doesnt seem like this is going to be something they are going to be fixing unless you want to spend a few hundred on it if they even consider wanting to fix these! Also the maps on the harddrive are much older than the DVD which the last year for these are 2013 and will no longer be making new maps for these cars from what I hear.
So two options:
You can keep the navi the way it is with a non functioning time which doesnt effect the navigation.
OR
Upgrade it to the new DVD unit....which has its plus it comes with the entire US map not like the harddrive which is limited to state if Im not mistaken.
I ended up going with the newer DVD Unit. Had a few issues at first but was eventually able to figure things out and is working with no issues and I have the time stamp now!
Old 09-17-2016, 07:34 PM
  #42
4th Gear
Kozfire2003's Avatar
Originally Posted by johnny14
Welcome to the club! Its definitely a software issue and to be honest with you with all the run around I was getting with Acura and the Navigation support it doesnt seem like this is going to be something they are going to be fixing unless you want to spend a few hundred on it if they even consider wanting to fix these! Also the maps on the harddrive are much older than the DVD which the last year for these are 2013 aill no longer be making new maps for these cars from what I hear.
So two options:
OR
how much did the DVD unit cost and where did you get it? Does it replace the navigation box in the trunk?
Old 09-17-2016, 11:24 PM
  #43
thewrangler99's Avatar
Clock is working again.
Old 09-18-2016, 01:21 PM
  #44
4th Gear
did it just start working on its own?
Old 09-18-2016, 01:44 PM
  #45
slowboat's Avatar
Me too! My wife and I swapped cars on Fri. 9/16 so I could change the oil on hers. She came home from work and said, " I fixed your clock."
Of course I didn't believe her and had to see for myself. I started the car and the time was correct. No more 0:00.
It's been holding the right time since.
Old 09-18-2016, 07:01 PM
  #46
paulmooney's Avatar
Reminds me of a good IT joke...A Programmer, a Field Engineer and a Salesman are driving across the desert when they get a flat tire. The salesman says, "Well, now we have to get a new car." The field engineer says, "I got a better idea. Let's rotate the tires and see if we can isolate the problem." The programmer says, "No let's keep driving and see if the problem goes away."
Old 09-19-2016, 11:48 AM
  #47
johnny14's Avatar
Wow so it just started working again? Interesting! Well that sucks for me but good for you all who didn't convert the DVD! lol Oh well glad its finally working and didn't cost money to fix it!
Old 09-27-2016, 05:19 PM
  #48
9th Gear
Huskie_Jon's Avatar
It is September 27, and my NAV clock is working again. I did not do anything. It just started working again.
Old 08-16-2017, 08:24 PM
  #49
doopstr's Avatar
Received 2,048 Likes on 1,135 Posts
Found this thread because this just happened in my 04 Honda Odyssey. Any update on a solid fix for this just hope that it starts working again?
Old 08-16-2017, 08:47 PM
  #50
MassiveTL's Avatar
I have a 2003 Acura TL with Navigation and the same issue just happened to me today!! My Navi Clock is showing 0:00
Old 08-16-2017, 10:29 PM
  #51
lateralus's Avatar
crazy on my 2003 cls when I left work today same thing with my navi clock 0:00... gave me that beautiful time in green when I left for work this morning lol..
Old 08-16-2017, 10:48 PM
  #52
SuperGreg's Avatar
Same here, 2002 TL-S, clock just went to 0:00 on the way home from work.
Old 08-16-2017, 10:50 PM
  #53
lateralus's Avatar
I've always wanted to go from navi to non navi.. have a couple tl's and cl's at the pick and pull to grab stuff from... might do it before fall..
Old 08-16-2017, 11:17 PM
  #54
vperkins2's Avatar
I'm the original owner of my '02 TL-S. And I just noticed this silly clock issue today, 16 Aug. 2017.
Now that's weird... at least 5 of us got this issue on the same day.
Old 08-17-2017, 12:18 AM
  #55
AnJo21's Avatar
Same
add me to the list. 2002 Acura TL Type S
clock started reading 0:00 today. 8.16.17
Old 08-17-2017, 07:46 AM
  #56
jack frazee's Avatar
Me Too
2001 MDX
Clock went to 0:00 on 8-16-2017 around 06:00 PM MST
Interesting!
Old 08-17-2017, 09:08 AM
  #57
frankjnjr's Avatar
2g Navi Clock Issue
2G TypeS w/navi 231,000 + miles, no issues, electrical or mechanical with this car. Started car as normal this a.m.. Navi screen booted-up, at which time i shut system off, as normal. Today, however, the Navi clock displayed 00:00??? I went directly to the set-up screen and attempted to re-set the clock. The clock feature will not adjust, in hours or minutes? I pulled the clock fuse, thinking maybe this action would re-set the Navi as well. The clock fuse re-set method did not correct the issue. Any Ideas or suggestions would be appreciated.
Old 08-17-2017, 09:09 AM
  #58
3rd Gear
KarlVB's Avatar
I find it interesting and possibly significant that there was a rash occurrence of this problem in 1999 TL's in late August 2016. Today -- 17 August 2017 -- the problem appeared in my 2000 TL. Since I haven't read where anyone has found a solution to the clock problem, I am hypothesizing that there may be a software flaw which causes this condition at a set number of days after system manufacture -- approximately 17 years after manufacture.
Old 08-17-2017, 09:37 AM
  #59
kayakmaster's Avatar
Yesterday My 2003 CL Type S developed the same clock issue. Navigation working, clock froze at 0:00 . Add me to the list of people whose clock stopped working yesterday 8/16/17
Old 08-17-2017, 09:43 AM
  #60
sunland man's Avatar
0:00 clock
Me too. 8/16/17. Between 5:00 or 6:00 pm.
Old 08-17-2017, 09:44 AM
  #61
2002 tl
Old 08-17-2017, 10:06 AM
  #62
johnny14's Avatar
This is definitely a software glitch thats happening about this time a year for these models! I had the same issue that happened to me last year with my old hard drive unit so I ended up converting to the 03 DVD unit and was working fine. Like you all I noticed that my time was displaying 0:00 again on the DVD unit, so around this time it appears that these units go into 0:00. From what Im hearing people are stating they just left it alone and it started showing the correct time again and hasnt happened again. So this time around Im just going to ride it out! I would advise to the same to you all as well.
Warzau (08-17-2017)
Old 08-17-2017, 10:10 AM
  #63
johnny14's Avatar
You are correct it appears to be a trend thats happening around this time a year for the TL's and CL's. Last year was mainly 99's. This year appears to be the 02 and 03's.
Old 08-17-2017, 10:28 AM
  #64
Unregistered Member
Karanx7's Avatar
Something weird is going on. on August 16th 2017, everyone with a navi is having their clocks turn to 0:00.
Old 08-17-2017, 10:54 AM
  #65
Iggy's Avatar
Add me to the list. 2002
Old 08-17-2017, 11:12 AM
  #66
4th Gear
Lupo_SHO's Avatar
Add me to the list. 2001 CL-S.
Clock started showing 0:00 yesterday 8/16/2017
Old 08-17-2017, 11:48 AM
  #67
jtraxler's Avatar
Add me to the list 8/16/2017 2000 TL...
Wonder if it ever self corrects say after day light savings time or something...
Old 08-17-2017, 12:24 PM
  #68
01RedCLS's Avatar
Add me to the list as well: '01 CL-S
Came here to find a solution!
Old 08-17-2017, 12:56 PM
  #69
SuperGreg's Avatar
Looks to be '00 - '03. Let's hope this fixes itself like the '99 did!!
B Sc (01-12-2021)
Old 08-17-2017, 12:58 PM
  #70
8th Gear
Warzau's Avatar
I was searching online for a resolution and saw this thread. I have a 2002 MDX and it happened to me as well YESTERDAY! 8/16/2017. I noticed it appox 8PM CST.
I disconnected the battery for 10 mins. Reconnected battery and waited for navi to acquire GPS lock nothing still the same. Then via diagnostic, reset the Navi to factory default, zilch. I went as far as getting the newest ( at least to me) and last update disc from Acura and overnight put in new Navi DVD. Nothing still the same.
Old 08-17-2017, 02:30 PM
  #71
johnny14's Avatar
The MDX uses the same Navigation as the 02-03 so it doesnt surprise me one bit. Im sure its a glitch in the system and will correct itself. Only question is when!?! I wonder if its going to happen to the other years eventually for example next year around this time for the 04 and up models. Would be interesting to see if that was the case.
Old 08-17-2017, 03:01 PM
  #72
7th Gear
Craig92117's Avatar
Add me too. My `01 CL time reads 0:00 and cannot set hours or minutes in the setup screen.
Old 08-17-2017, 03:43 PM
  #73
frankjnjr's Avatar
Add me to the list as well, 03 TLS. Just noticed it this a.m. Unable to re-set clock, just displays 00:00. If it fixes itself, this will be the first time anything on any of my cars has ever fixed itself. LOL
Old 08-17-2017, 03:54 PM
  #74
7th Gear
Kmizzal00TL's Avatar
Same thing for me, '00 TL.
Old 08-17-2017, 03:56 PM
  #75
frankjnjr's Avatar
I stumbled on another thread from last year regarding this very issue. For some reason, the thread did not appear when i searched for (navi clock issue) It appears that this is not a unique problem, and that everything from disconnecting the battery, the navi unit itself and replacing the navi internal battery, had no effect on the problem. Than, the problem mysteriously corrected itself, and the clock function went back to normal! ??? Guess I'll wait and see what happens.
Old 08-17-2017, 04:02 PM
  #76
johnny14's Avatar
Whats weird is that on my 99 hard drive version I was able to set it but it didnt stick after restart. The DVD drive I cant even change the time.
Old 08-17-2017, 04:21 PM
  #77
9th Gear
Acurlover's Avatar
Happened Yesterday to Me too 2003 TL
So weird! I am glad I found this thread. I tried to change the clock in settings but it wouldn't budge from 0:00. Rest of Navigation working fine. Guess I will have to wait to see if it self corrects
Jax818 (09-26-2017)
Old 08-17-2017, 04:28 PM
  #78
rambleon's Avatar
I'm glad i checked this site. My NAVI clock went to 0:00 today for the first time ---- '03 TL/S. It seems from all the prior posts, there is not a fix to this. That 3V battery in the DVD trunk unit doesn't seem to have anything to do with it. It makes sense that there is an internal software problem which is triggered by today's date. I was going to eject the last DVD and re-install, but it seems like a waste of time. It must be some bad code in the software. I doubt it will fix itself, but you never know. My car is still like new, but i guess i can live without a clock.... too bad.
Old 08-17-2017, 04:43 PM
  #79
rambleon's Avatar
Just an add-on to my prior post. The clock time won't even reset or respond to the menu. I have the NAVI unit and when i go to the setup screen, the time won't even adjust at all. It just stays on 0:00. I initially thought i could just reset the time, but it is like it is frozen. The time never moves by hitting the hour or the minute icon.What a bizarre problem. On my '03TL, the last NAVI DVD upgrade was in 2013 --- 10 years. I received a letter saying there would be no further upgrades so i bought the last one. At this point it is probably obsolete anyway. Smartphone GPS programs are probably better anyway, but it is such a bummer to have a perfect car after all these years and the damn clock doesn't work.....LOL And the issue for me is i don't even have a smart phone.....
Old 08-17-2017, 04:44 PM
  #80
johnny14's Avatar
People Ive talked to as well as previous posts on here all stated it just randomly started to work out of the blue. Time frames may vary but Im pretty sure it will start to work again. I believe i was the only one that converted to the DVD from the previous posts. Should have stated with my original lol. :p
The following 2 users liked this post by johnny14:
Acurlover (08-17-2017), rambleon (08-17-2017)
Quick Reply: Navigation works but clock not working
