My 6 speed swap thread
3 pedals in my 99 TL
Sup everyone,
So recently my tranny went bad on me after being replaced at 184k miles. Before starting the swap my car took me all the way to 231k miles when it finally broke down. So now I'm in the process of a 6 speed swap and thought I'd post some pics of my progress. I'll update as I go along but here's a bunch for starters. Figured I'd try and post pics and add to the few other 6 spd threads who have made threads already which have helped me a lot when deciding to tackle this myself. Also, hopefully it helps those who decide to try it in the future!
Before tearing out the interior
Seats out
All that junk in the trunk
Getting ready to pull out the motor
6 speed FTW! LOL
Misc engine parts
Workin on that axle!
Gutted out
Thats all for now. I've got a few videos too but the old motor is basically pulled out I just have to remove the auto shifter cables from the firewall and then take out my old cluster and put in the new motor and tranny and rewire everything. I've got a lot of questions too so I'll post more as I go deeper into putting it back together.
Seats out
6 speed FTW! LOL
Misc engine parts
Gutted out
00 ssm
Nice. You beat me to making a swap thread. I'm in the process of doing my swap but I'm keeping my -p motor. So far I've got just the interior gutted and the handbrake installed and adjusted. Holes for the clutch pedal ready as well. I just got delayed a few days ago with the work though because of life stuff but I will be working on it every weekend from here on out hopefully. This weekend I plan to pull the motor. If I can help with anything I'll try, seeing as how we're at similar stages. I'm attempting everything myself in my garage at my parents house so I'm sure I'll find myself asking some questions.
Good luck man.
Thanks guys yea ive had a lot of helping hands along the way but for the most part me and my friend have been putting in the work on everything. Its my first time ever doing anything like this and i think i made pretty good timing for the first few days i worked on it. Got the motor basically out and interior all gutted in 3 days time. Then i havent worked on it since cause ive been busy.
Alright, so got some more work done today and yesterday. Pulled out the old ebrake and cables and also took out the cluster to get ready to swap the new one in. All thats basically left is to remove the old motor mounts and wait for the new motor and tranny and 6 spd parts to get here then swap em in. Heres some pics of my progress.
Motor and tranny out!
Dont worry I'm going to get a picture of myself in the engine bay because Ive always wanted to do that hahaha
Motor and tranny on the cherry picker
And heres todays work.
Before the cluster came out
Cluster out
Empty cluster area
Misc. parts
Clutch pedal spot that I have to drill out still
Old ebrake and cable out. This was a pain in the ass because the fuse box and wiring were in the way of one bolt towards the top near the steering column. Had to unplug a bunch of shit just to get my ratchet to reach up there and have enough room to loosen it. Finally came out after like half an hour when I found the right extension to give me enough clearance.
Fuse box wiring
Old ebrake and cables
Thats it for now. Will post more later on when more progress happens
Cluster out
Empty cluster area
Misc. parts
Fuse box wiring
Yea the easiest part is over I think. I'm definitely going to need help later because putting everything back together is going to be a whole different story than taking everything out.
Oh also one more thing I forgot to add. I'm planning on cleaning and washing out the dirty ass engine bay and washing everything down so it looks new and clean and debating on a wire tuck? It would definitely be fun and look even better when I pop the hood and probably would be easier since the motors already out. So yea thats probably gonna happen too.
MechEng
^ that would make for some very awkward clutch placement. there is a specific spot that needs to be drilled in order to bolt the clutch pedal in. its essentially the same spot as in the CL.
You know you cannot used the auto rear mount an you will need removed weight damper thingy to right of it. After you remove weight damper it going make easier to run cable link throw it. Also why didn't you remove J piped all the way? You know make it easier to reinstall engine.
Since your using 99 TL are you running Richvie module or swap out all the wire?
B/c J32A2 engine don't have the same speed sensor an temperature plug. These are things i ran into when i did my swap.. (easy fix)
Keep up GOOD WORK
Keep up GOOD WORK
Yea Im well aware that the rear motor mount is different from the manual one. Just havent removed the motor mounts yet but I'm getting new ones from the CLS 6spd so no problems there. And I'm not all the way done with everything yet like the J pipe I've been just doing a few things at a time for now because the new parts arent here yet.
Also, I'm not using my TLP motor so no need for the richie module since I'm swapping out all the wiring from the auto to manual harness from the 6 spd CLS motor. But thanks for the tips bro! Did lots of research before I started this so I'd run into as little problems as possible once I started!
Keep up GOOD WORK
Keep up GOOD WORK
This. I posted a specific picture of where the clutch pedal is going in my pics up above. Like 03tls said it would be an awkward place if i put the clutch where the old ebrake was lol.
And Sway Ive got all the parts I need for the 6spd swap (motor, tranny, 6 spd parts) their getting shipped out to me from NJ so once they get here I'll be set to go and just swap everything in
00 ssm
Was that from a honda/acura salvage yard that had around 115k miles on it? Lol i was looking at one complete swap from NJ a month ago so I'm just curious. And the way I removed that e-brake mount was by grinding away the bottom portion with a dremel and then just bent the piece back and forth until the metal fatigued and broke off. Hope that helps you out if you have troubles cutting it off.
Yea I got the ebrake mount off already. Made enough space in there to unscrew it. And the parts I got were actually from a member on here not from a salvage yard.
00 ssm
Oh ok gotchya. I think I know of the sale you're talking about. My transmission threw a code a week after I first saw that fs thread Congrats on picking that up that was a great deal!
Are there any threads around here pertaining to just installing a 6-speed in a car that's already a Type-S? A lot of these threads seem to be overkill for people like me who already have the Type-S and I imagine things may be slightly different (and easier) for us aside from the fact that we aren't installing an engine.
00 ssm
Thanks man it's all good haha. Progress has been real slow lately since I've been busy with work and other stuff. Haven't done anything since the motor came out
Got some more work done on the car today. Took out all the motor mounts and removed the engine wiring harness from the firewall and the ECU while I was at it.
Engine harness
Removed from the firewall
Front mount
Side
Rear
Bay
Wires out and detached from the ECU
Side mount gone
Front mount gone
Rear gone and weight damper before I took it out
Weight damper gone
ECU
4 days after I turned 10 years old, this car was meant for me!
Just had a question. Since I removed the weight damper next to the rear mount am I going to have to put it back once I put in the new mounts or will the clutch lines get in the way when I go to install them?
Engine harness
Front mount
Side
Rear
Bay
Side mount gone
Front mount gone
Weight damper gone
ECU
They stay removed. And any one looking to loose a little weight in their car should remove them as well.
mugenspire (09-08-2011)
Got pretty much all the rest of the work done today that I needed to. I wanted to finish prepping up the car before the motor comes in tomorrow so that way its ready to go right in! Heres just a few pics. Took out the firewall spot weld bracket and drilled the holes for the new ebrake near the center console.
Taking out this bracket was a pain in the ass! I used a drill, flathead and a hammer to get it out after like 3 hours total. Lots of drilling, prying, pulling, yanking, cussing, bleeding and sweating. Finally got that thing out though!
Bracket gone
close up
Didnt get any pics of the 2 holes i drilled for the ebrake cables but its pretty self explanatory.
Also, I pretty much finished drilling out the spot welds through the firewall in order to mount the clutch pedal I just didnt take any pics of it. Got too tired and excited once I finally removed that damn bracket. Motor will be in tomorrow and then the real progress will begin!
Bracket gone
close up
