Is my 03 TLS done for? Loud squealing from upper manifold please any ideas - AcuraZine - Acura Enthusiast Community
Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003)
Reload this Page >
Notices
Old 12-01-2018, 02:48 PM
Registered Member
I may have to cave and take my car to the dealer just to be told my engine is done for : (
Loud squealing coming from upper manifold cover, def not power steering and I just changed my pcv valve but the noise didn't go away.
When I accelerate the noise goes away. My car drives fine, no rough idle, no problems starting, no problems accelerating -- but this noise is gut wrenching. It's the loudest whistle/squeal and it seems to reduce slightly if I press down on the upper manifold cover. I verified the upper cover gasket is on properly and broke a bolt over torquing but I don't think my upper manifold cover not being on tight enough would cause a noise this loud. Any ideas? My car drives great and I don't have any symptoms of a vacuum leak, just a VERY loud audible noise which is certainly not coming from the power steering pump. It doesn't sound like a belt either. I'm at a loss for ideas.
Link of the noise is below. Any ideas would be greatly appreciated.
Knicee is offline
Old 12-01-2018, 02:50 PM
Registered Member
I only get the noise when in idle and when I'm not accelerating. No change in noise when turning the wheel. Should I just cave and take it to the dealer?
Knicee is offline
Old 12-01-2018, 03:06 PM
Registered Member
No error codes using both a obd2 scanner and a honda scanner with dealer software preloaded.
Knicee is offline
Old 12-01-2018, 08:12 PM
Registered Member
horseshoez's Avatar
Given your description of what is happening and how your car drives, I'm at a loss as to how you could possibly come to the conclusion your engine is done for. I cannot opine as to what the problem is, but I believe your engine has plenty of life left in it.
horseshoez is online now
The Following User Says Thank You to horseshoez For This Useful Post:
justnspace (12-01-2018)
Old 12-01-2018, 08:46 PM
you broke a bolt....now the manifold isnt tight and leaking air...perhaps its just air ??????????????????????
you dont have to take it to the dealer, just fix the bolt
justnspace is online now
Project_CLean
First Generation CL Discussion (1997-1999)
18
06-22-2011 02:14 PM
Kyin01
1G & 2G MDX Discussion (2001-2013)
03-27-2011 11:19 PM
fliplyricist1
35
06-28-2008 09:24 PM
willz822
Third Generation TL (2004-2008)
21
08-30-2004 11:42 AM
Quick Reply: Is my 03 TLS done for? Loud squealing from upper manifold please any ideas
