moonroof noise,driver seat loud squeeky noise,dash noise..anyone know solutions?
guys...
My driver seat squeeks really loud when i am driving or going over bumpy roades... solutions?
my moon roof makes noise while driving and bumpy noise...
solutions?
dashboard makes a lil rubbing noise... solutions?
anyone knows how to solve the problem or have experienced it and got it fixed?
I know some of this has been posted...but just want to know the exact answers for these problems..
Thanks, lates
city
solutions?
Thanks, lates
city
Ex TL-S owner
Ditto......I got my sunroof fixed by the dealer and it's quiet now. I really want to say something about the rattles in my dash, but I don't want to be so picky. I bet they wouldn't even know how to fix it. Is it worth a try? Has anyone actually gotten the dealer to fix dash noises?
i did pay a trip to the dealer to fix the dash rattle, squeeky driver seat & the front wheel fender. a little bit better than before. however, the plastic fender is broken again two days ago. sh?t! also, i figured out that the noise fm the driver seat actually coming fm the connection btw the seat & the seat belt connector. once u move the connector a little bit, the noise is gone. but i will pay another trip to the dealer as the fender & the rattle are driving me crazy.
Ex TL-S owner
Originally posted by city001
where's the wheel liner located at?????
city
city
The "old" guy
Yep....squeeky seat here too. I had the dealer fix it and they told me it would come back...and they were right! Im taking it in for its second oil change, tire rotation and tranny flush shortly....I think I'll ask them about the seat again too.....
Dash rattle
My TLS has dash rattle. At first, Acura of Pleasanton put
in some tape around the instrument plastic panel and
the soft vinyl dash. The squeaking noise is gone. After
2 weeks, new source of rattle appears. It sounds like
some clip on the instrument panel is coming loose. This
rattle is really hard to reproduce. It comes and goes and
happens often during nighttime.
If I pressed on the panel, the rattle seems to be stopped.
I couldn't reproduce it at dealership. Perhaps I might try
it again in my next oil change visit.
If anyone had the dash rattle fixed, perhaps you can share
your info with us. That might help dealer to find the source
too
-- william
too
-- william
Shogun Assassin
Does Honda assembling plant suck or what???
let's all write a complaint to honda.
My TL-S was squeak & rattle free until about 4,500 miles. Then the sunroof squeak started almost overnight and it was *very* loud. Lucikly the stereo goes even louder. My closest dealer is over an hour away so I didn't want to make the trip just for the sunroof issue. I decided to wait until something else cropped up. Well, I registered at acura.com for the owner's link and discovered my '02 fell under the seatbelt recall (never got a letter BTW--thanks Acura). And I thought I had a noisy idler pulley as well (although that was a "could not duplicate" and hasn't returned since). However, from the time I first started hearing the sunroof squeak until the day I brought the car in for service, I *thought* I started hearing a bunch of squeaks from various other places in the front of the car (dash, center column, etc). The dealer applied the teflon tape to the sunroof opening and the car is now perfectly silent. No squeaks, moans or groans anywhere.
Moral of the story: if you haven't fixed the sunroof squeak, what you *think* may be coming from the dash area could be coming from over your head. Sound sources can play funny tricks on your ears in an auto environment. Try the sunroof fix first. It's quick and easy at the dealer.
To fix the drivers side squeak, spray some WD40 in the seatbelt receptacle. The buckle rubs against the sides producing a slight squeak; mine is now gone.
For the sunroof the dealer has a fix, so let them do it!!!!!!! The problem is known and they have a known fix invloving a clear gasket that goes arounf the sunroof opening. When going on unlevel surfaces the ar frame twists at a different rate than the glass, and the rubber gasket around the glass rubs against the paint producing the noise. The gasket they apply wont make that noise.
my car makes a sound like theres a lil ball rolling in the side and everytime i gas or brake i hear it roll and come to a stop, sounds like its coming from the column that the seatbelt is in, anyone else have this?
