Low Beam installation
Old 01-07-2008, 05:19 AM
im2nice4u's Avatar
Hi all,
i have an acura TL 03 and i need to change my low beam light
where can i get it??
and how to install it?? (is it hard??)
thank you!!
Old 01-07-2008, 07:18 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
You should buy 2 new HIDs. They should be replaced in pairs.
As for the instructions, there is a #20 security torx screw you have to remove.
After its removed you have to twist the black cover about a 1/4 turn (it shows on the cover which way to turn)
After its turned you can pull it out of the way. Then there is a metal clip that is a spring loaded that you push in and move to the side. Once thats is uncliped the bulb simply pulls out.
(The bulb is removed to show the clip)
Be careful not to touch the new bulb as the oils from your finger will cause them to burn out.
Contact our vendor Excelerate for good replacement bulbs.
Old 01-19-2008, 06:41 PM
bonknhead's Avatar
Thanks for the pics Kris! I just changed my HIDs and your pics made it a breeze.
Old 01-19-2008, 07:11 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Those Kaixen bulbs from Excelerate are rocknroll
You can get 5000k which is really close to the stock color 4300k bulbs white with a little blue tint
Or the 6000k has a much bluer with white color, and is great for night and bad weather driving or those with night vision problems in general.
Old 01-22-2008, 10:34 AM
bonknhead's Avatar
I just noticed that the Philips 4300k I just installed are very white, without any of the hint of blue that my 5-year-old stock (OSRAM) 4300k bulbs had. I've read that the color of HIDs settle a bit after something like 100 hours. Will they get a little bluer?
Old 01-23-2008, 12:48 AM
Registered Pimp
burnerjunky's Avatar
i like the 8000k, i know il prob get flamed for saying it, but its like my own portable rave wherever i go, neon colors everywhere
The following 2 users liked this post by burnerjunky:
JmannTLs03 (11-17-2012), KatabaticSaint (09-26-2011)
Old 01-23-2008, 07:01 AM
fsttyms1's Avatar
Why would you want blue? Blue doesnt help you see. Im probably going to get a set of kaixen 5k and compare them to the 6 i have as they are just a little blue for my liking and know i can get better useable light from them.
Old 01-23-2008, 03:07 PM
Registered Pimp
yes, it doesn't make things brighter, but, it makes things more vibrant. the road lines and reflectors come back at you in neon colors and its just like being on a big ecstasy trip
Old 01-23-2008, 03:22 PM
bonknhead's Avatar
I really liked that tiny bit of blue tint my stock 4300k HIDs had. IMO it looked upscale without being ricey.
So back to my original question, will the new 4300k bulbs eventually become a little bit bluer like my 5-yr-old stock ones did, or is that only when they're at the end of their life?
Old 01-23-2008, 05:16 PM
Registered Pimp
they go pink when they are about to die, also i noticed, you can tell how used your bulb is if you take it out and look at that little bubble in the tube, the more wear on it, the whiter and milkier it gets.
Old 01-23-2008, 05:28 PM
fsttyms1's Avatar
IMHO Blue doesnt make them look upscale. Pure white would, but not blue.
They take about 100hrs to color shift. After that thats about all they will change. As bulbs get older they dont turn bluer. they will eventually start looking more like halogens and shift to a pinkish color as they are about to die.
Old 01-23-2008, 06:07 PM
01tl4tl's Avatar
Kris- based on info from Excelerate and info on Kx website- the rating system for color and how its measured in the old days versus now with modern equipment, the Kaixen 5000 are almost the same as OE 4300 for color white with blue, but you have to admit, having the road lines jump out is very helpful
6k is more blue with white
Oh wait- you dont think seat heat is needed in -30F weather, so how much should we trust.....
At least you can give another ziner a good deal on slightly used bulbs if you prefer the 5s.
I'm old, I appreciate the way the lines and signs show up like they did not with the 4300.
Old 01-23-2008, 06:43 PM
fsttyms1's Avatar
They are bright, but they seem to strain my eyes with the blue.
Old 01-23-2008, 07:17 PM
bonknhead's Avatar
So after 100 hrs, when they color shift - do they get even whiter? Or pinker? What color do they "shift" to?
Old 01-23-2008, 10:46 PM
01tl4tl's Avatar
your 4300 will get a little more blue in them. If you get pink- its time to buy new bulbs
Wow Kris- blue is supposed to be easier on the eyes, I hope my reputation points havn't been cut!
I was reading today that the Kelvin color rating is about the eyes abilty to differentiate
colors- which would explain why 6000 ks make reflecto paint light up so well
Sunlight would be 12k for example and yellow fog lights are 3000
Old 01-24-2008, 03:49 AM
AZP-TL's Avatar
http://www.sizes.com/units/color_temperature.htm
Old 01-24-2008, 10:27 AM
Bob_F's Avatar
From what I've read, 4300K is the best bulb temperature in terms of maximizing visibility at night and for minimizing eye strain.
Here's a great link with an extended discussion of this:
http://intellexual.net/hid.html
Here's an excerpt:
"....Philips is the number one manufacturer of HID bulbs. The Philips OEM D2S bulb is rated at 4100K at 12.8 volts and produces 3200 lumens of light. The Philips Ultinon D2S is 5800K at 12.8 volts and produces 2400 lumens of light. As you can see, with all other factors remaining constant, the brightness of an HID bulb declines the higher up the color index you go. Vision, a Korean bulb manufacturer, makes an 8000K bulb, which they used to advertise on Acura-Forums as 2000 lumens bright. This is barely a marked improvement over halogens, and will produce more glare and eye fatigue than it is beneficial. 4100K has been proven through tireless independent research by the Germans, Japanese, and Americans to be the most functional, truest white and thus the brightest possible color temperature (ceteris paribus).
Every car manufacturer in the world (including BMW and Audi) uses none other than a standard 4100K gas-discharge bulb. No exceptions. The reason being is that 4100K is daylight white in color and produces the same color visible light as direct sunlight. This is least fatiguing functional color on the eyes and produces the most comfortable contrast on the road."
Old 01-24-2008, 11:04 AM
01tl4tl's Avatar
How old is that info though bob?- Kaixen is the international research facilty for lighting- based in Korea (your tax dollars at work?) and they hold several new patents on design and manufacture for their factory division.
I dont have a set of 5s to compare, the 6s are working very well for my old tired eyes, thats all I care. I have run next to an 03TL and the OE lights do have more ~white~ directly in front of the car. If thats really important to you- go with the 4300 or 5000 bulbs
Look at current german cars- they sure look blue when I approach one or being passed.
Everyone has different taste, I found outdoor house flourescent floodlights-
6500k, and like them too
You can always add pinpoint beam driving lights for distance or some wide angle close range. My year didnt come with fog lights so adding lighting is normal to me
Old 01-24-2008, 11:11 AM
Bob_F's Avatar
Yes, that's correct. The blue coloration is due to the use of projectors.
Here's more from that same link:
"So the million dollar question is now: Why do BMW & Audi lights appear blue when they use a white bulb?
Well, this coloration is the result of the light projectors; the lenses: it's transparency, it's curvature, the tiny grooves etched into it; the projector assembly, the shield, and the reflector bowl. All these components work together to produce a signature of light unique to that particular optic's design. On the Audi and BMW projectors, the lens curvature at the edge bends the white light producing a "prism effect". White light is broken down to it's fundemental colors. Since blue lights is high energy, it is absorbed last and thus travels farther. So with this prism effect, you'll notice that BMW HIDs are only purple and blue from the sides, the top, and the bottom edges, but are always daylight white on the road and in the beam pattern. This phenomenon can be demonstrated when you watch an oncoming BMW hit a pot hole or speed bump in the road and the car's nose pitches up and down. The headlights will flicker and "throw colors off", but returns to a solid white beam pattern directly on the road.
Trying to emulate this color-flickering effect with a solid-state blue or purple bulb is only detrimental to lighting performance, it doesn't fool anyone, but most importantly it endangers other motorists around you. Blue light has what we call a very high diffuse density, which causes it to radiate outwards as opposed to forwards. What results is a wide glow of light outside the beam pattern that is blinding to motorists you share the road with. A blue HID bulb will produce color bleed around the headlight, around the objects it lights up, outside of the beam pattern, and around the cut off line. This is effect is known as "glare", and these illegal and improperly installed HID kits are the reason why HIDs get a bad wrap. As common evidence of glare, observe a traffic light at night in a dimly lit area. There is red light and green light. Red is opposite blue and green is next to blue, thus we can substitute green for blue. If you observe the aura, or glow, of light around a red light and compare it to that of a green light, you'll notice that the green light produces much more glare than red. Blue is even worse. Purple, the worst."
Old 05-23-2008, 05:14 PM
dlee1234's Avatar
hey all,
im trying to replace my driver side HID lowbeams, but when trying to follow the steps, there is a plastic vent of some sort last doesnt allow me to pull out the black cover in order to get to the HID Bulb. can any1 help? am i supposed to take out the entire headlight from the front? thanx
Old 05-23-2008, 08:24 PM
Bob_F's Avatar
Originally Posted by dlee1234
hey all,
All the vent pieces on the driver side will pull out without any tools. (I don't recall if there are two or three pieces.) But the top vent piece has a couple of "pull-back" connectors that you'll need to retract before you can remove it.
Old 05-23-2008, 10:02 PM
...advance...
maniaC_99's Avatar
just pull that plastic piece out
and you will have all the room u need.
just did mine 3 weeks ago
Old 06-28-2008, 12:01 PM
Anachostic's Avatar
I just finished mine (wow, typing hurts. My fingers are so sore). It took me about an hour and a half. Learn from my mistakes. For the record, I am anything but "handy". Sometimes, it really shows, too.
My biggest mistake was not paying attention to how the bulb and harness were mounted into the lens. When you are looking down into the hood from the front of the car, the wires for the harness should be facing right. I kept trying to mount it with the wires facing down without any success. The retaining spring would never catch. There is a key in the lens that matches up with a notch in the bulb. Although it's not really a snug fit, like halogen bulbs are, and it's hard to notice because of the spring in the way, it is there.
While I was struggling with this, I thought maybe the bulb was interfering somehow. So I decided I should figure out how to asemble it without the bulb. This led to my next mistake. The retaining spring is NOT meant to secure the bulb harness. The diameter of the bulb where the spring is is smaller than the harness. So by me trying to mount an empty harness into the lens, I bent the crap out of the retaining spring. It took a lot of time to rebend it to a suitable shape.
After finally figuring out that you had to have a bulb in the harness and you have to have the harness wires pointing right, it went fairly easy. I disassembled the crap out of the driver's side so I could see what was going on.
If I had to do it again, I would. It's not that hard. I made it very difficult all on my own.
Old 07-06-2008, 07:28 PM
No He Can't
6MTUA5's Avatar
I'd say my bulb was done
Old 07-07-2008, 12:07 AM
mrchan625's Avatar
if i were to replace my bulbs do i also need to replace the ballasts or is that okay?
Old 07-07-2008, 04:23 PM
No He Can't
6MTUA5's Avatar
Not if your current ballasts still work
Old 07-07-2008, 04:32 PM
Lamborghini Aventador FTW
AMGala's Avatar
It exploded on its own? Or did you hit it while installing/removing it?
Old 07-07-2008, 05:21 PM
No He Can't
6MTUA5's Avatar
I'm not sure, the bulb had been out for a while and I finally got the chance to open it up and I pulled it out. I could have hit it, but I think it was like that before.
Old 07-12-2008, 10:11 AM
3rd Gear
DRSMOKE's Avatar
I just replaced my low beam HIDs using this thread, made it a breeze. Only had to watch on the orientation of the bulbs when I installed the new ones, they will only seat flush if the notches in the bulb are at 11 o'clock when you are looking at them from the rear. Other than that, seating the cover was a bit tricky but all-in-all it went so much easier than I had envisioned
I replaced both bulbs, one was out and the other was blinking. The one that was out had been blinking for sometime before it went and when I pulled it out it was totally blown, exploded, like the one in the picture. Like AMGala, it had been out for awhile before I replaced.
FYI - I have a 2000 TL with 302,000 so the bulbs were due...
Old 11-23-2008, 08:10 PM
`ill*tl's Avatar
DRSMOKE, could you possibly take a pic. of how the notches should look with the bulb sitting in the power socket? I for the life of me can't get it back in properly to set the security pin. I have been trying for the past 4hrs now.. and now its dark. So I'll have to wait until tomorrow morning to give it another shot. I have tried all sorts of placements in the power socket from it being snug and locked into that little key too having it placed half way (turned) into the power socket.
Edit* Crap.. forgot how old this thread is.
Old 11-23-2008, 08:32 PM
No He Can't
6MTUA5's Avatar
If you put the thing that's holding the bulb up against the housing and start turning, the notches will find where they are supposed to go and it will set in right. Then, you can attach the clip from there.
Old 11-24-2008, 04:30 PM
greeeneyes1200's Avatar
So I am facing this issue today and Im wondering about the danger of replacing the low beam. Is there a safe way to make sure there is no charge built up in the light? Also, im having difficulty finding the #20 security screw, is it any different in a '99?
Old 11-24-2008, 06:34 PM
No He Can't
6MTUA5's Avatar
Nope.. #20 Torx for the 99.. Just make sure to unplug everything before you start touching stuff. I was handling that igniter like it was plutonium.
Old 11-25-2008, 03:22 AM
`ill*tl's Avatar
lol, yah.. it took me tearing apart my front end to figure out what I was doing wrong. I was trying to put the power harness back in with the security pin in the way. It took me 2mins to figure it out when I had the headlight casing out on my kitchen table.. so stupid of me!
Old 11-25-2008, 07:28 AM
fsttyms1's Avatar
If you were closer and i saw your issue sooner i would have come and helped ya.
Old 01-02-2010, 08:15 PM
Notorious7645's Avatar
hey guys would i need to take off my front bumper to install my HID's in the low beams or can i get to it without taking off the bumper?
Old 02-22-2011, 01:04 PM
jomama's Avatar
no need to remove the bumper to replace driver side bulb!!!
2000TL-P headlight bulb replacement
finally got around to replacing my headlights this weekend. my driver's side one went out a week or two ago so i ordered a pair of phillips D2Rs from amazon for about $90 total. when i removed the broken bulb, it was in pieces like the one 6MTUA5 showed in post #24.
anyways, i wanted to add a little to this DIY so that those looking to change their driver's side bulb will know that you don't need to remove the bumper.
1. there's a removable plastic shrouding just south of the airbox (facing the front of the car, north being driver's seat, west being passenger side, etc.) and east of the battery (sorry, i don't have a pic of this) that's held on by two clip and anchored by a third clip at the bottom. if you remove these two clips that hold the plastic piece to the frame, you will be able to pull up on the shrouding and it will come off. it might take a little encouragement, but it comes off for sure.
2. once you have that removed, you will see an air duct that opens up to the west (see below pic - i'm holding the removable duct). that piece comes off as well. just give that duct a good tug in the up direction and voila, you now have access to the igniter.
3. next, remove the security torx screw shown by the OP. after that's been removed, you can't quite twist off the igniter just yet - you should disconnect the grey clip that's connected to the turn signal, i believe. grey piece will be to the outside of the car from the igniter in either headlight assembly.
4. once you have removed that, you can twist the igniter off. it takes a bit of force, but it does come off.
5. another trick that might make this process easier is to remove the connector from the bulb before removing the bulb (and replacing it after replacing the bulb). the connector piece is the one with the "Danger" sign taped on it. that piece, obviously, may be detached from the bulb. while the bulb is still in the housing, you can push the connector towards the housing and turn it counter-clockwise slightly. the connector should come off pretty easily. after you've done that, you can simply remove the bulb by removing the metal clip shown in the 4th and 5th pics by the OP.
given the limited space, it's a bit cumbersome to try to put the new bulb back in when the connector's attached. i found putting the bulb in and clipping it makes it much easier.
sorry if none of this makes sense just reading it, but you'll understand what i mean once you're under the hood of your car.
Old 02-23-2011, 04:46 PM
8th Gear
drifter_1775's Avatar
i paid about $95 for a pair of 8000k D2R bulbs and they're not as blue as i would have thought, but they work great at night
Old 09-23-2011, 10:12 PM
thescarletnecklace's Avatar
Removal of bulb?
I am all the way down to removing the bulb and can't seem to remove it from it's socket. I have tried twisting in both directions, also while pushing and pulling. I saw the direction arrows on the back of the socket for "open" and "lock", but that didn't seem to help me out at all. Is there something I'm doing wrong?
Old 09-24-2011, 12:00 AM
pickler's Avatar
double post
Quick Reply: Low Beam installation
