Loose lighter/accessory socket
Old 09-18-2011, 05:09 PM
Severin's Avatar
Question Loose lighter/accessory socket
The accessory socket near the coin tray on my car is loose; it rotates and can be pulled out 1/4 inch.
I found the following thread:
https://acurazine.com/forums/showthr...lighter+socket
However, no one mentions what needs to be disassembled in order to get there. Can I get away removing the nearest side panel to do this? I assume there's a nut in back or either the sleeve is the nut, I can't tell from the parts diagram.
Thanks.
Old 09-18-2011, 05:33 PM
2000 TL Black on Beige
Sperry's Avatar
Yes, the sleeve is threaded. Carefully pry the RH "wood" trim off the console,
and you'll be able to access the accessory socket. It pries out and up, if memory serves.
Old 09-18-2011, 08:30 PM
Severin's Avatar
Thanks!
Old 09-19-2011, 11:01 AM
totaledTL's Avatar
Did you look in the DIY sticky? 3rd link from the bottom of the pg.-
Old 09-19-2011, 06:05 PM
Severin's Avatar
Apparently not! Thanks - missed that in a search.
Old 09-19-2011, 08:13 PM
Severin's Avatar
Fixed! An easy way to tighten it given the limited space is to tighten the sleeve by using a flat bladed screw driver and and hammer against one of the splines on the sleeve after you've gotten it finger tight.
IBankMouse
06-13-2020 12:53 PM
ITSJESTER
17
12-06-2018 02:29 AM
dainmezron
10-16-2015 06:56 PM
Skirmich
10-01-2015 12:59 PM
MilanoRedDashR
09-27-2015 10:15 PM
Quick Reply: Loose lighter/accessory socket
