Just changed my Tranny Fluid
#42
Well checking when engine is cold is the wrong method. I believe you need to go drive for ~10~15 min, pull over & then check level of fluid on level surface.
texholdem (07-02-2012)
#44
texholdem (07-03-2012)
#48
2000 TL Black on Beige
I'd bet bottom dot cold = top dot hot. I just checked after a 30 mile errand, and I'm all of 2mm over the top dot, if that. It might even be less, because the fluid sloshes around when being pumped through the system, and the inside of the dip tube may receive fluid.
In the beginning, I heard everything about "measure exactly what comes out", etc etc etc.
Well, if the wrong amount is in there coming out, you wouldn't want to put the wrong amount in.
I'm happy with 3 quarts out, three quarts in. Seems like it works perfectly.
Maybe, for whatever reason, some cars may be 3.1 or 3.25 quarts per D/F.
#49
nanos
11-12-2015 08:41 PM
HydrasunGQ
09-14-2015 10:14 PM
HeloDown
09-08-2015 06:51 PM
