honda ATF-WD1 vs ATF-Z1
so when to honda Dealer to get some AFT for my Acura CLs they give me the honda ATF-WD1 instead the regular ATF-Z1 fluit that i use to get, so my question is, is there any difference between them two before i change it?
ATF DW-1 was developed for improved low temperature performance. It is to be used on 2011, and newer, model-year vehicles, and it is backwards compatible to previous model years. ATF DW-1 is the primary ATF for Honda and Acura vehicles.
<--see avatar. it applies here
Only Group IV (PAO) and Group V (Ester) base stocks are not petroleum based.
I am not offering advice, in this case, just information.
Sperry (09-23-2011)
Unregistered Member
It is petroleum based. It is made from Group III base stock. This means it is made from crude oil, but goes through a process called hydrocracking.
So there's overlap between petro based and fully synthetic? Is there a wiki page I could read up on this?
There are FIVE groups of lubricants ... Group I through Group V. The first three are all refined from crude oil. The latter two are made from non-petroleum components.
The best explanation that I can give on Group III would be this:
Imagine that crude oil has 50 elements, each with equal parts. In the case of a Group III lubricant, it is completely taken apart in a lengthy refining process (hydrocracking - blasting with hydrogen to "disassemble"). After that, the undesirable elements are discarded and the desirable elements are reassembled in a specific order AND with specific amounts of each. In many countries, these Group III lubricants are called "Full Synthetic", while others ban the practice and reserve the term "Full Synthetic" for products with 100% Group IV and/or Group V content. While Group III base stocks are fully reengineered, fully redesigned and completely different than crude oil - they are petroleum-based lubricants.
Group IV (PAO) and Group V (Ester) are getting more involved daily. They have been used to "boost" motor oils for some time. Acura RDX Ultimate is one example. It is a Group III interlaced with a Group IV. This offers additional heat protection for the turbo package. It specifically meets the Honda HTO-06 specification. Anyone owning a RDX should be fully aware of this and be sure NOT to introduce an oil that doesn't meet/exceed the HTO-06 requirement. In addition, there are motor oils which are based solely on Group IV and/or Group V stock. While they do have some advantages, there are also disadvantages ... as with everything else in life.
I did find a Wiki page with information. It isn't perfect, but it is close enough ... http://en.wikipedia.org/wiki/Lubricant.
And where we can see if DW-1 is Group III? From the Smell of it, It does look and smell like AMSOIL Full Synthetic or that is Group III as well??
In any case for the OP just use DW-1.
In this particular case, you will have to take my word for it. If it were Group IV or Group V, you would be assured of the fact when you entered the parts department ... they are considerably more expensive base stocks.
In respect to the AMSOIL product, I quickly reviewed the technical data (PDS and MSDS) available on their website and it does appear to be a Group III based product. In addition, it seems to be more expensive than Honda/Acura ATF DW-1.
Its not a full syn, it even says on the bottle contains petroleum oil. So its most likely a Group 3 (which in america can be called a syn even though its not a full syn)
Hello,
For 2000 TL's, or even older cars, i.e. acuras/hondas. If I initially usw ATF-Z1, then now I change with 3.2 quarts of DW-1, for a 60-65 dollar transmission service.
Is that acceptable, will that be okay even though the transmission has over 75k-115k miles on it.
Thanks for any advice.
Quick question... Going to the dealer to get my SRS light checked out. While I'm there I am thinking of getting a trans service (drain and fill). They are using the new fluid, if they just do the 1 drain and fill, is it ok that the 2 different fluids are mixed? Or do I need to do the fill 3x3? Thanks
'12 & '13 AL West Champs!
Red Line formulates fully-synthetic oils and chemically-advanced additives using the world’s finest base stocks. Rather than cutting costs by blending in petroleum products, Red Line's motor oils and gear oils use superior ester base stocks that provide extreme stability at high temperatures and superior film strength at lower viscosities where more power can be produced.
