HID Ballast or Ignitor issue ? - AcuraZine - Acura Enthusiast Community
Notices
Old 12-26-2010, 06:51 PM
New Member
Recently changed out my HID with new Bulbs as one had gone out. The Drivers side which had gone out now is fine. The passenger side which i was not having any issues is now acting up. It not coming on all the time.
I have narrowed it down to not coming on when you initially turn the headlights on, sometime it comes on and sometimes it does not. If it does come on it will Stay on until you shut the lights off and re-turn on at which time it will not come on immediately after it has been o for a while. If you wait a while it will seem to come back on.
I am wondering if I have a bad Ballast or bad igniter ?
No Moisture in lens and the intermitent issue has only started after I changed out bulbs, which leads me to lean torward the igniter side be bad ?
Any thoughts ?
citystop is offline
Old 12-27-2010, 01:23 AM
I'm a thrill seeker in my
TheMegalodon's Avatar
If I remember correctly, I think I was having a similar problem with no noticeable physical signs of issue. I had recently changed the driver's side ballast because of moisture failure. The passenger side started having intermittent problems functioning normally, similar to what you're experiencing. I figured the ballast had died, ordered a new one on ebay for 200 shipped, replaced the broken one and all was well.
I'm thinking it might be your ballast. Often there isn't a problem with the igniter, it's usually the ballast.
TheMegalodon is offline
Old 04-28-2014, 09:43 AM
Registered Member
Having a similar issue has anyone pinpointed the cause of this problem ballast?
Lester86 is offline
Old 04-28-2014, 10:12 AM
06 NBP 6MT TL
cincinattlguy19's Avatar
Moisture is usually the death of the OEM ballasts. Your best bet would to be replace it with aftermarket, as the ballast and igniter become one entity, and it is significantly cheaper than buying a new OEM ballast. Remember to replace everything in pairs as well.
Try taking a look around www.theretrofitsource.com, plenty of great products, and great customer service as well!
cincinattlguy19 is offline
Old 04-29-2014, 09:42 PM
Registered Member
another azine tested source is www.hidextra.com
get the 35 watt system with 5000k color bulbs $59 look for coupon online too
easy diy- a few wire cuts, there are a few DIYs on here
01tl4tl is offline
Old 04-30-2014, 01:56 PM
DRINKING HAS A ME PROBLEM
Rpappi's Avatar
what's the consensus on the 55w kit from www.HIDextra.com.
I searched but couldn't find much on reviews of them.
Rpappi is offline
Old 04-30-2014, 02:25 PM
06 NBP 6MT TL
Stock ballasts push 35 watts, and 35 watts is plenty enough. I wouldn't go up to 55 watts for a couple of reasons:
1. Our headlights were designed for 35 watts, and anything more would cause glare.
2. The temperature of the light itself is generally higher, running a larger risk of melting something.
Just stick to the 35 watt ballasts, as they are a better solution, and also usually the same price anyways!
Old 05-08-2014, 10:48 PM
Registered Member
most likely ballast, i had the same problem, replaced the bulbs and still had it. Then bought new ballasts, lights are now perfect.
2ndgentlMike is offline
Old 05-08-2014, 10:51 PM
Registered Member
I actually swapped out the Igniter and all is well Thank you Ebay only cost me 45$ hope it lasts :-)
Lester86 is offline
The Following User Says Thank You to Lester86 For This Useful Post:
todhazel (02-23-2019)
Old 11-20-2017, 11:26 AM
New Member
did you have any water damage to the ballast or how did you know to just change the ignitor?
JMRD92 is offline
Old 02-23-2019, 07:10 AM
New Member
From my recent experience, this what I gathered:
My lights did not work at all. Replaced the bulbs, now lights would come on intermittently and work fine till they were turned off again. Then they might turn on and they might not. (each light would act separately from the other, the left might act up or the right might act up randomly)
I replaced the ballast and it still did the "turning on intermittently" thing. Once you got it on, it worked fine till you turned it off. If you turned it off, you would have to wait about 45 seconds before they would even try to turn back on. (like something had to reset)
Then I realized there was an IGNITER! The name kinda gives away its purpose..... I replaced the igniter and the lights pop on every time without hesitation.
I just wanted to share this because I didn't find very many answers to an "intermittent not turning on" issue.
todhazel is offline
BoricuaTL
04-08-2016 01:08 PM
benny_jdm
01-31-2016 06:15 AM
gehrlichman
09-22-2015 10:08 AM
acuraST
First Generation TSX Discussion (2004-2008)
09-17-2015 02:31 AM
theinsvnity
09-10-2015 10:22 PM
Quick Reply: HID Ballast or Ignitor issue ?
