Hickam Series J32a2 TURBO swapped car
Figured I would post my build thread in here since my swap is a J32a2 out of a 02-03 TL. I've got a tons of pics so hang on tight...
[img]https://i32.photobucket.com/albums/d7/93civic96ls/J32%
20Project/6f9421aa.jpg[/img]
It's really hard to show the real color with pics, but here is the best I could do with my damn apple phone...
[IMG]http://i32.photobucket.com/albums/d7/93civic96ls/J32%
20Project/00eccafc.jpg[/IMG]
removed the rear drum brakes
Here you can see the sump on the fuel tank and where I mounted the pump and filter
Out with the old
And I took the subframe spacers out so I can get them powdercoated since I forgot them when I got the subframe powder coated
Stainless lines just hanging out waiting for the rear suspension
[IMG]
http://i32.photobucket.com/albums/d7/93civic96ls/J32%20Project/DSCF3292.jpg[/IMG]
Out with the old
[IMG]
Cleaned up shifter cable bracket by cutting this extra piece off. Sending it to powdercoat soon
Tore the steering rack apart so I could powdercoat it
Tore transmission apart so I can powdercoat the housing. The internals are huge
Look at the size of that final drive
Reverse has syncro
Shifter mechanism before modifying it for k series shifter
Case ready for powder coat
Reverse has syncro
Moved the shift linkage pin from the hole in the right to the left. This is needed to run 02-06 Rsx shifter on 04-07 tl transmission. This piece is also getting powder coated black.
Started fitting up my new turbo manifold. The other one wouldn't fit with the radiator I planned on building
Got 2 runners tacked up now
20Project/79535a8c.jpg[/IMG]
Tacked last runner on the front and also welded 16an fitting to stock coolant pipe (I won't be using this anymore. So it is for sell if anyone is interested...)
Tucked the intercooler real tight. Real pleased with how it sits. However, shortly after doing this, I decided to build my own intercooler and running a bigger front so this intercooler and brackets are for sell.
Built my 4" aluminum exhaust. Will go 3.4" downpipe straight to 4" exhaust with no muffler or resonators... all I want to hear is the raw aluminum sound
Cut the rear bumper for the exhaust. Love the way it looks
Also got 4 hydraflow clamps for my radiator pipes. The are for 1.5" tubing. Figured they will flow better than the 1" -16an lines
