Help! - Windshield Wipers Going Crazy
Old 10-07-2003, 03:00 PM
B93P TL Owner
mdavisii's Avatar
Hello -
Is anyone experiencing an issue with their wipers where sometimes they "slam" down too far on the windshield (sounds very annoying afterwhile)? I had Acura take a look at this, and was informed that the "scissor assembly" is bad and would have to be replaced. Is this something I can do on my own, or is this something that needs to be left up to the professionals? From what I am told, this has been a problem for Second Generation TL models.
P.S. They did adjust the blades, but because there is so much play with this the effect is pretty much still the same.
Old 10-07-2003, 03:52 PM
I was having the same problem. I am actually going to replace the part this weekend, but I have already taken apart things to find the defective part. It is really not that difficult, probably something you could do. If you done things like changing spark plugs, etc. on cars in the past then I would just do it yourself.
Old 10-07-2003, 05:03 PM
B93P TL Owner
mdavisii's Avatar
Hey,
Would you mind telling me how to go about taking everything apart? I am assuming everything's behind the black strip the wiper arms rest on. And how much did you pay for this "scissor assembly" part? Thanks for the feedback!
Old 10-07-2003, 05:45 PM
8th Gear
Out of curiosity, did your wipers also wipe to far across the windshield? Sometimes mine slam down on the cowl as you mentioned and other times they switch and the drivers side will slam into the a-pillar. It seems to get worse the faster I go. I even had it get stuck past the a-pillar once when I was on the highway.
Old 10-08-2003, 08:23 AM
B93P TL Owner
mdavisii's Avatar
Yes my car experiences the exact same thing. The faster you go the worse it is (sometimes). Looks like you need that scissor assembly as well. It makes me wonder why there isn't a TSB on this issue if it is such a common problem as the dealer indicated.
Old 10-08-2003, 11:55 AM
8th Gear
It would appear so. I'll try to call the dealer today to get a part number on that and let you know if emfrench hasn't responded by then...
Old 10-08-2003, 12:24 PM
B93P TL Owner
mdavisii's Avatar
Thanks!
Old 10-08-2003, 01:12 PM
Rock Star
nym31mp's Avatar
is it a dealerhsip thing that they can do under warrenty therefore u dont have 2 pay or it it something where u have 2 just replace the bad part w a better part.......peace
Old 10-27-2003, 10:16 AM
B93P TL Owner
mdavisii's Avatar
Has anyone had any success with repairing the wiper assembly? Mine is getting to be unbearable and will probably look into repairing real soon. Thanks!
Old 02-06-2005, 07:38 PM
Any luck on fixing this? Mines been doing it forever and it's really starting to get on my nerves.
Old 02-06-2005, 08:51 PM
soccerbenk's Avatar
yews i just had this problem and fixed it it was a linkage arm thatr wears out the part cost $19 and i replaced it myself and now my wipers are fine
Old 02-06-2005, 08:54 PM
Cool, thanks.
Old 02-07-2005, 11:08 AM
B93P TL Owner
mdavisii's Avatar
I fixed this problem myself. Purchased a used transmission (scissor) assembly from the junkyard about a year ago. Haven't had a problem since.
TheMuffinMan
06-02-2022 07:11 AM
bluetl04
08-16-2016 02:49 PM
blacktsxwagon
10-27-2015 10:12 PM
merc009
09-29-2015 03:06 PM
rhdune16
09-28-2015 11:31 AM
Quick Reply: Help! - Windshield Wipers Going Crazy
