What is a good budget axle and motor mounts?
Old 08-24-2015, 09:51 AM
02tlnate's Avatar
looking for a good budget axle and motor mounts. because of my bad mounts and them beening the original with 206k they have worn out my cv axles that i replaced 20k miles ago. I hear that people have issues with certain cv axles not fitting and I would rather not run into this issue. what is a good axle that is inexpensive like under $70 that work good. I will probably be buying the full kit on ebay that comes with hydralic front and back for only $85 bucks. Im not worried about idle vibrations but just dont want my axles to be wearing down and bending after 20k miles
Old 08-24-2015, 01:34 PM
rcb2000's Avatar
don't go cheap on the axles you'll just end up replacing them again. And be sure and torque the nut or you will shorten the life of the wheel bearing.
Old 08-24-2015, 02:13 PM
ndoghuntsville's Avatar
That's what I meant by budget. I dont have a lot of money but enough to get a decent set. I want raxles but they cost to much. I got my passenger side for $45 a year and a half ago but I'm just seeing what all there is and what works for people
Old 08-25-2015, 12:17 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
NAPA axles are all brand new parts and used by many on here,,figure 75-100$ for each
Old 08-25-2015, 12:19 AM
01tl4tl's Avatar
got a link to the motor mount package? that's unusually cheap!
The engine and trans not shifting around will help the axle bearings too
Old 08-27-2015, 05:55 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Id spend the little extra and get OEM, they are far superior to aftermarket and rebuilts you get at parts stores
02-25-2020 09:57 AM
wilztlxs
12-01-2015 09:16 AM
BKSleeper
10-07-2015 10:20 AM
mossman77
1/2G MDX (2001-2013)
18
09-16-2015 12:21 PM
NSolace
09-03-2015 08:02 PM
Quick Reply: What is a good budget axle and motor mounts?
