Help, Motor Mount question
I'm pretty sure I need to replace a motor mount or two. I'm hearing some rough sounds going over bumps at low speeds and gears are hitting pretty hard between reverse and drive as well as shifts. I don't have much experience with hydraulic mounts. I replaced the side mount and my front mount appears to move around half an inch or so and looks to move a quarter inch or so in the rear. Is this amount of movement unusual for it to be parked and just switching from reverse to drive and back. Could I be having issues other than a mount or is there a better way to determine if one needs to be replaced?
Thanks in advance,
Will
Thanks in advance,
Will
Mr.Helpful Diagram
These mounts allow a bit of movement, as long as you don't hear a thud while testing them for movement they are ok.
When were they changed? if never consider changing them you will feel a difference.
Yeah, if the car has 100k and unsure if the mounts have ever been replaced....just do them. When the front mount goes bad, it'll tear up the top side mount. Check the other suspension components and bushings for wear. Make sure that the tranny fluid is at the correct fill level.
Thanks in advance,
Will
Thanks in advance,
Will
I don't foresee the install to be too difficult, just from hearing that noise and testing the mounts I was surprised at the amount of movement I saw.
Bump sounds and hard shifts.....
The side mount is the only one that has been replaced and that was about 20k ago. I'm looking at about 144k now. The only thud I heard while testing it seemed to be coming from the transmission (which was replaced about 10k ago). And if the mounts aren't bed then I need to find what's making that noise, it doesn't really inspire confidence in my front end. I didn't go too deep into a suspension inspection, but I shook what I could around to try and make the noise I'm hearing, but wasn't able to. The front and back mounts are original side is about 10k old.
Hey Jwp1013, If the tranny was just recently replaced.....one could only assume that the shop would've checked the mounts at that time ? Ya could take it back to the shop if ya think that the tranny is the noise.
The 5 piece mount aftermarket kit can be purchased for less than $150. At 144K on the dial, it may be a good place to start, IMO. Also on a 10 year old car......many things in the front suspension/steering could be worn and causing thumpin' & bumpin' sounds. It's the process of elimination, start with the easiest and cheapest things first !
Also have a quick question about motor mounts. Car is making a rattle noise when it is in Drive. I throw it in Neutral and it stops. I'm thinking it could be a mount. Anybody got any ideas??
You can start by checking the side mount by just looking at it. If it is ripped you probably also have a failed front mount. Or you and a buddy can do the brake test to see if they are bad.
Rattle noise in "Drive".......
Bad mounts usually clunk ....not rattle.
Have ya checked anything else that may possibly be loose and causing the rattling sound ?
Could be the exhaust system, maybe the converter shields or a rubber hanger ?
Former Sponsor
If you need to replace your mounts I'd consider upgrading to our XLR8 mounts. They are much more durable than the OE mounts and other aftermarket options.
http://hoa.excelerateperformance.com...i-1804873.aspx
