Help me diagnose this symptom
Old 01-20-2005, 03:21 AM
Chloe @ 17mo
AsianRage's Avatar
A while ago, and just recently, I noticed that my car shudders just a bit when I was driving on I-5. I came out of the express at 60 something mph, I might have released the gas pedal just a bit, before applying further pressure, and just as I was pressuring hte pedal, I felt the car/engine/tranny shudder a slight second before it accelerate. The closest comparison I could make is if you were to be experience a slow shiver, or when you try to swallow nothing.
I know it's hard to describe, but with the tranny issue looming, I can't help but feel worried. I've felt it two times this week. The last time was last year...
Thanks for any suggestions.
Old 01-20-2005, 07:45 AM
lover and fighter
r10apple's Avatar
If you almost feel a "shift" in the engine or gas pedal, could be a motor mount is fried.
I tend to think it just might be the car trying to find the right gear between 4/5 when you dip off the throttle. Mine has always done that, albeit a bit slower 45/50mph with the old tranny, around 50/55mph with the new one. It's a slight shudder as if the car is deciding to downshift-briefly engages-then goes back to 5th with a little tip in with the throttle again...
Old 01-20-2005, 08:02 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Mine does that too. It's normal.
Old 01-20-2005, 01:11 PM
TLStar
Faizalstar's Avatar
that little computer has alot to do when trying to figure out which gear to stay with in a second, happens to me also.
Old 01-20-2005, 01:22 PM
B93P TL Owner
mdavisii's Avatar
Completely normal.
I believe that would be the torque converter locking back in. On some of our cars the torque converter lockup will cause a slight shudder, which the tech tells me is very common. No need to worry, your transmission should be fine.
SidhuSaaB
05-30-2020 12:40 AM
MilanoRedDashR
10-08-2015 10:30 AM
us285126
10-02-2015 02:03 PM
thegipper
09-28-2015 01:01 PM
Brandle34
09-23-2015 07:20 PM
Quick Reply: Help me diagnose this symptom
