Fuel injectors
Old 01-16-2014, 12:19 AM
Bricktop's Avatar
Fuel injectors
A question about the injectors. Do they need to be replaced after so many miles? My car has 162254 miles on it.
Is there a way to check them using a voltmeter?
I'll be removing the intake manifold to clean out the EGR passage way.
Old 01-16-2014, 07:23 AM
3.2TLc's Avatar
There's no reason to replace the fuel injectors unless you have a definite problem or reason to believe that they are bad. Most times, simply running a good quality fuel system cleaner in the gas tank a couple of times a year will suffice. Sometimes with a fuel delivery problem, it may be contaminated fuel or a fuel pressure issue.
So, if everything's normal and the car is running well....don't replace the injectors. Cleaning them and possibly replacing the o-ring seals if needed, is all that you might want to consider at your present mileage.
Old 01-16-2014, 07:24 PM
Bricktop's Avatar
A can of seafoam in the tank?
Sometimes i get a slight bumpiness when it's idling.
other then that the car runs fine. No check engine light. Spark plugs have 17,000 miles on them.
When i have the manifold off the car i'll clean throttle plate and check idle control valve.
Old 01-16-2014, 08:15 PM
Mr.Helpful Diagram
ErickUa5's Avatar
Yup no need to replace them, No CEL leave them alone. A bad injector makes the engine run rich and shake in idle at all times.
Definitely do the egr and iacv cleaning that should help.
Old 01-17-2014, 08:31 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
do not try to clean the injectors manually
simply run a can of seafoam in half a tank of gas- thats 2 oz per gal for max allowed `cleaning strength`
Do that twice and the entire system from tank- thru lines and injectors- and out the exhaust including cat -will get cleaned..seafoam likes time and heat
you are running the correct 8 dollar each ngk?
plan on cleaning the iacv rod slit and chamber = it will be clogging
dont forget a new 5$ pcv valve
while manifold is off: if you live where its hot summers or hard use driving, and have a 100 bucks handy, the intake heat spacer is very cool,,so to speak see theads on outlaw engineering
get those egr ports all 6-clean and main passage thru manifold, as well as lube arm on actual egr valve
Old 01-18-2014, 12:03 AM
Bricktop's Avatar
I have NGK ZFR6FIX11 Iridium IX plugs. They have 18,508 miles on them.
PCV has 3,522 miles on it.
Ran a can of seafoam , how soon should i use another can?
Old 01-18-2014, 08:36 AM
Nicks2001tl's Avatar
You should be good to go with one can for now. I usually put a can in before winter and in the spring. Run a 1/2 can through the vacuum line also. Also run 1/2 can through the crankcase before an oil change.
Seafoam does a great job cleaning carbon build up. Takes the moisture out of the gas tank, cleans the fuel lines and injectors.
If you really think it`s the injectors the only way to truly clean them is to pull them out and have them professionally cleaned. Otherwise the seafoam should be adequate.
Old 01-20-2014, 09:04 PM
01tl4tl's Avatar
seafoam for first timers is 1 can to half tank of gas
then another can when another tank within a month gets down to half
you want miles- times for best results
when doing twice in gas there is ZERO need for vac line method
DO clean TB air plate--separate operation from any method of seafoam
then twice a year do a can in half to mostly full tank
do gas at oil change to remember
at oil change = half a can in oil and drive a week then change with oil warm
Old 04-10-2014, 08:06 PM
Bricktop's Avatar
I finally got around to removing the intake manifold to clean out the EGR passage ways and EGR valve.
While the manifold was off, i connected a digital ohm meter to the fuel injectors.
Here's the results
cyl 1 - 13.1 Ω
cyl 2 - 13.1 Ω
cyl 3 - 13 Ω
cyl 4 - 13 Ω
cyl 5 - 13 Ω
cyl 6 - 12.6 Ω
I looked thru the service manual and i couldn't find the ohm range spec on these injectors.
I hope these numbers are ok.
Old 04-10-2014, 08:54 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
^ Ohm reading wont tell you if they are clogged though... That's to find a faulty Injector which is a very rare case.
Run Seafoam in half tank and run good Gas 91octane quality and they should last you a lifetime.
Old 04-11-2014, 07:39 AM
3.2TLc's Avatar
Hey Bricktop, did cleaning the EGR passageways and IAC valve help with your previous lumpy idle issues ?
Old 04-11-2014, 12:56 PM
Bricktop's Avatar
It's smoother at idle now, with an occasional a hint of roughness (if that make any sense).
Before i would get some bad shaking, as if the engine spinning at a low RPM(would happen in sub 20's weather). But it never stalls.
In the few hundred miles since the cleaning, i haven't had that happen again.
With a 163710 miles on it, the engine still feels strong.
Old 04-11-2014, 07:25 PM
3.2TLc's Avatar
Check all the vac hoses and electrical connections. Replace the air cleaner if it's been awhile.
joflewbyu2
08-18-2019 10:38 PM
LeVeL
10-18-2015 04:19 PM
ExcelerateRep
10-14-2015 08:20 AM
joflewbyu2
10-08-2015 11:16 AM
Quick Reply: Fuel injectors
