Free Service Manual
2003 TL-S A-SPEC
Free Service Manual
for library card number enter 123456789 submit, submit Hudson Library, scroll down to AUTO REPAIR REFERENCE CENTER, pick year, make and model.
OPLIN Research Database Remote Access
http://www.oplin.org/databases/proxy...%2fframerq.asp
1. card number 123456789
2. click submit, then again.
3. scroll down.
4. thank me.
3. scroll down.
4. thank me.
Received 1,080 Likes
Originally Posted by acutee
It does not appear to have J32A2 engine, but still great info to refer to.
It has a TypeS vs Non-TypeS section. Doesn't it show the J32A2 for the S?
Awesome Memeber
1 Post
Thanks BIGTUFFGUY! Found out how to remove the wrinkled trim and replace it.
I have downloaded most documents already, once I get home I will post unless someone else has already done so.
If you looked at Specifications, it only lists upto 2002, and j32a1 engine only.
OM NOM NOM NOM
1 Post
what are you looking for on the 2002 type-s. i found it on the 2003 type-s. all the info is there including the diagrams i might need if i need to rewire my car for the 6mt motor
I selected type-s, but the info is good up to 2002 model, and only has engine J32A1.
AZ Community Team
Received 7,770 Likes
AWESOME!!
Nice find.
Nice find.
Is this direct link not good?
http://arrc.epnet.com.oh0049.oplin.o...ain.autorefctr
Yeah it works!!!!!!
Yeah it works!!!!!!
After the second "submit" I get this message. Anyone know what I have to do????
To allow http://arrc.epnet.com/autoasp/index....ain.autorefctr to be used in a starting point URL, your EZproxy administrator must first authorize the hostname of this URL in the ezproxy.cfg file.
Within this database's section of ezproxy.cfg, the following line must be added:
Host arrc.epnet.com
The EZproxy server must then be restarted to make the change take effect
Host arrc.epnet.com
Where did you find the doc about the wrinkled trim. I looked under 03 TL-S and I couldn't find it.
are you going to try to fix your trim? Not sure if i have time yet, let me know if u do it
Originally Posted by Rajca
u could buy some vinyl over lays from SSMTL01 for $42.50 shipped
Not the Pillars the cheap black tape that goes around the windows that gets WRINKLED. The pillars don't wrinkle, the vinyl overlays are for the pillars not around the window.
Either way I would paint both the pillars and the wrinkled trim tape after removing, much cheaper than $42.50. All it is is the cost of paint, clear coat, and some sandpaper.
