Notices
Fan in 1999 Acura TL under hood keeps blowing
Old 05-07-2019, 04:24 PM
Registered Member
crimebeck890's Avatar
This keeps blowing loudly for 5-10 minutes after car is shut off after a drive. It is not too hot here yet in Austin.
Hello,
You can see in the picture attached that this is the fan I am referring to. Is it normal for this to keep blowing up to 5 to 7 minutes after I shut the car off?
Thanks for reading.
crimebeck890 is offline
Old 05-08-2019, 02:20 AM
Registered Member
whitetiger5's Avatar
There could be a few reasons why this is occurring, here are a few:
  1. low coolant
  2. air in the cooling system
  3. a leaking water pump causing low coolant
  4. a faulty temperature sensor
the choice keywords to see how others tackled the issue.
google.com/#q=fan+on+engine+off+site:acurazine.com
whitetiger5 is offline
Old 05-08-2019, 07:19 AM
Registered Member
Thanks for the reply. I got a coolant flush only three months ago. I check my fluids twice a week - everything looks good. I also had work done on it Saturday and it was looked at for a while - no mention of any leaks. How can I test the air in the cooling system and faulty temperature sensor? The temp in my car on the dash is usually accurate. Is this a pressing issue in general?
Old 05-08-2019, 11:52 AM
Registered Member
If the temperature is accurate (doesn't fluctuate) then I wouldn't look any further in that area. The service manual has a troubleshooting table on page 10-19 that you could use to take make a proper diagnosis.
Any chance you found any other threads with others having the same problem? If not, please share your findings for those of us still around.
Old 05-08-2019, 04:27 PM
Registered Member
Thank you. It only occurs on hot days - 80+. It is "only" 72 degrees here in Austin today and it has not occurred. About to go check my coolant and water pump one more time, but based off the helpful google search you gave me, people say that as long as the fan does not blow for over 10 minutes, it's no cause for alarm. Cheers.
Old 05-08-2019, 04:30 PM
Registered Member
CL-S24's Avatar
Check the main relay in the fuse box
CL-S24 is offline
Old 05-10-2019, 05:43 PM
Registered Member
My 99 was doing that until I replaced the temperature sending unit.
Here's the testing procedure:
Note that I replaced mine because I accidentally broke it off and it fixed the issue incidentally - be sure to run the test first.
The part # they sell on RockAuto for our year is also incorrect. It fails the test above and makes your gauge look like the engine is critically overheating. I ended up just pulling a handful from the junkyard, and the first one I plugged in worked.
Good luck!
Arkady is offline
KraftwerkTurbo
First Generation NSX (1990-2005)
10-24-2018 06:37 PM
Sueilyn
02-22-2018 01:28 PM
jdmej1
03-21-2013 05:17 PM
Gunny Highway
07-13-2008 03:08 PM
muser23
07-20-2006 05:03 PM
Quick Reply: Fan in 1999 Acura TL under hood keeps blowing
