exhaust leak...
exhaust leak...
so i just replaced my oil pan this past weekend and to do so i had to unbolt the down pipe from the headers. well all is good except i have a check engine light on and a exhaust leak out of both flange attachments should i just get new gaskets? if not what else would solve the problem to also make the check engine light go off
Yes, new gaskets maybhelp. Unless you cracked it downstream
which one exactly because the flange from the down pipe looks like part no. 31645 but on there diagram it says to use part no. 31377.... im so confused
What's diagram are you using? Those aren't typical Honda/Acura part numbers
