Engine still misfiring
Old 07-29-2011, 11:18 AM
6th Gear
SuperDan's Avatar
I replaced all my spark plugs, but it's still misfiring. Any help please? Could it be my coil packs? if so how much does it cost?
Old 07-29-2011, 12:23 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Most likely just 1 coilpack. Buy one and and start putting it on 1 cyl at a time till the misfire goes away.
U can get them for like 55 bucks
Old 07-29-2011, 03:06 PM
Boomer SOONER
ou sig's Avatar
rockauto.com has them for $35 - $50 each
Old 07-29-2011, 05:02 PM
3 pedals in my 99 TL
mugenspire's Avatar
this. and make sure to reset the ECU after u find out which coil is bad.
Old 07-29-2011, 05:41 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
exactly what plugs did you install? NGK Iridium? were they about 8 dollars each?
are you getting multi cyl misfire codes?
thats usually 1 coil bad as said above
did it miss before the plugs?
have you done the egr port/passage system clean yet? that will cause a miss
did I come in on the middle of this story -already in progress? any backstory??
Old 07-29-2011, 05:44 PM
01tl4tl's Avatar
when doing the try new coil on each cylinder (start with ones listed by codes)
reset the ecu after each coil movement
if doing the test method of remove the power lead to coil and ck for rpm drop or no drop, you dont have to reset ecu- just plug wire back in tight and remove next ones till the rpm doesnt change = the dead one
SidhuSaaB
05-30-2020 12:40 AM
BIGxRED
10-19-2015 10:47 PM
joflewbyu2
10-08-2015 11:16 AM
ROSSARONIE
10-02-2015 11:46 AM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: Engine still misfiring
