Engine code P1607
B A N N E D
1 Post
Engine code P1607
well my engine light came on after my dom unit and dvd install. I had the code read and it said
P1607
manufacturer contrl
aux imput
aux output
can someone tell me wht this means? did i just screw myself over and am i gonna have to dump mad amounts of money at the dealer to fix it?
P1607
manufacturer contrl
aux imput
aux output
B A N N E D
1 Post
thanx tom..
now tht i think about i accidentally pulled the starter signal fuse plugged it back in and turned the car on. any chance that this could have set it off? my car seems to be running fine i drove it all day yesterday and today
ഥഎണഡഏ Fellas Inc.
just check them all with a fuse tester or you can look at them too and see if they are broken. i would do this with my battery disconnected (negative) to rule out blowing more fuses lol...
my abs and tcs lights went off last week (by themselves) -- now my maintenance flashes and SRS stays on haha (i pulled srs out a couple of times -- long story)
g luck
g luck
B A N N E D
1 Post
thanx bro ill check them. i gotta an opointment with the dealer tomm lets see wht they gotta say. do they need to reset the light or can autozone do it if the fuse is the problem or will it go away on its own if i fix it?
Did you try resetting the ECU to see if they come back?
B A N N E D
1 Post
diagnostic is only free if its not my fault, the service rep kinda fucked up my world. he said that P1607 is the tranny code and that since i have a aftermarket intake the light could be caused by that. in which case its my fault. i know this is bull shit but after my OE spacer install went wrong i had to use some liqud metal stuff to seal my TB till my OEM gasket came in the mail. I'm thinking that this is what set off the code and im gonna install my gasket put my oem intake back in and take it to a different dealer.
B A N N E D
1 Post
well the guy did a code check even tho i said no and he told me the transmission computer was bad so they ordered a new one. everything is covered under warranty thank god.
HeloDown
09-08-2015 06:51 PM
