rotor replacement
Head Wanker
rotor replacement
Hello all. It's about time I replaced my OEM rotors (91k miles, had them resurfaced at 45k) and was wondering what folks here would suggest. I am more concerned with warping than performance (so no BBK for me ). I tried to do a search but it was not working for me but since I am a long time lurker, the consensus in the past IIRC is:
1) Rotora with Axxis pads
2) Brembo blanks with ? (I looked up Akebono ProACT Ceramic Pads on tirerack)
Rotora's complaints (again IIRC) were possible early warping and squeaking. I don't recall any complaints for the Brembo blanks but I could have missed them. Again, my biggest beef is with warpage (mine began to exhibit the characteristic vibration after ~27k miles like clockwork new and after resurfacing) and am hoping for something better than OEM in this regard.
Also, any suggestions on where I purchase them from? I am leaning towards tirerack as the prices seem decent and they have always promptly delivered for me in the past (for wheels anyway).
AZ Community Team
Received 7,770 Likes
Either:
Racing Brake from site vendor Mr HeelToe (www.heeltoeauto.com)
OR
Rotora from site vendor Excelerate (www.excelerateperformance.com)
OR
StopTech from either of the above vendors.
OR
OR
let the vendors suggest a pad for your driving style--
they know what works best on what rotors--and its not going to be akebono~
for normal street drivers either the brembo blanks or stoptech are fine
The other 2 mentioned are excellent upgrades for more spirited drivers
Gen 2 TL/CL remember we can use dual piston calipers for a 95 legend-- increased brake pressure to the pads and rotors and more pad stabilty--really makes the upgrade rotor/pads work at their designed best
and the calipers cost the same as TL calipers
FLUSH the brake fluid before doing any work on the brakes
I need 2 more gears
I just installed Racing Brakes slotted rotors, Racing Brake ET300 pads, Racing brakes SS lines, Legend 2 piston calipers and used Amsoil DOT 4 fluid and I doubt my brakes ever warp again. The difference is outstanding and gets better and better the more they "wear in". They aren't that expensive either.
Either:
OR
OR
OR
OR
on heeltoe use the build your own combo- it should be in the drop down choices
or PM both places for a price--include your zipcode and ask for pad suggestion
heeltoe has a discount code on his signature- acurazinerocks
Boomer SOONER
I put on the Brembo blanks and Satisfied ceramic pads from tirerack. All is fine except they rotors warped after about 50k miles. I do not drive hard or anything, and I was very easy on everything the first few thousand miles.
What your problem is?
1. Search is your friend...
2. Check out this thread and the recommendation SodaLuvr made to me and others... LINK.
SodaLuvr made a recommendation (Post #6) and that is what I went with (Post#57).... If you like these pads and want to buy them, I have an extra set of pads and will sell them to you... Let me know.
Another thread (about pads):
Brake Pads - https://acurazine.com/forums/2g-tl-1999-2003-98/new-brake-pads-706754/
The beast within
I would avoid Brembo rotors...unless they are high end, & even then.
Put Brembo & Satisfied GS6 pads, and the rotors are slightly warped already after only 20k miles, not enough to cut/replace them yet, but enough to go more expensive next time. The satisfied GS6 pads however are excellent, saved me twice from an accident...& they do stop great....with lots of brake dust as a side effect.
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
