DIY-MDX, Pilot, Odyssey spacer install
#90
I kinda want to buy the spacer and try installing with my 09 tl im. It looks like you will have around 1/2" of extra space with the tl im and from looking at ur pics even if you dremel the hood it still looks like you need a lil closer to 1". Has noone tried this yet still?
#91
B A N N E D
having a 09 manifold will mean that you won't have to trim or pop the hood as much, and you may not even have to pop the hood at all
anyways look at e30cabrio's, i think he also has the spacer with the 09 manifold
also civicdrivr i think has it too
#99
B A N N E D
and he needs all the help he can get on his slow ass P , to even be able to keep up with a stock S, that had some heavy ass 20" rims on it too (also the S needs a complete tune up also ;plugs, t/belt, valve adjust, etc., etc.)
#114
philly flickin'
Pics of IM spacer:
https://acurazine.com/forums/2g-tl-photograph-gallery-99/03-tl-s-w-mdx-im-spacer-%3D-intense-cali-lift-766318/
#115
01 acura tl type s swap
i got a 01 tl with the type s swap i know i have to cut and put spacers on the hood but how is it when it rains does it get wet under the hood bad or no?
#116
B A N N E D
all electrical connectors are sealed under the hood, so a little water won't hurt a thing under there, but if you take a fire hose (or even a constant garden hose) you might have another story though
remember water comes through the radiater already some, and from the underside also with the wheels spraying it up and such, so i would not be worried about it too much
