DIY - Door Lock Knob Adjustment
Well, I have had my car for about 5 months now and it has always bothered me that I cannot put my elbow in the corner of the window and hold my hand on the top of the window. Also, if I hit the lock while I'm driving, the doors all lock. This doesn't bother me until I stop, the door handle doesn't auto unlock the door. The same thing happens with my girlfriend in the passenger seat and she locks herself in.
I decided to take off the door panels and modified the knobs as such:
Door panel removal can be found in the Door Handle LED’s DYI created by CaliChris517
First, just unscrew the knob from the threaded post.
Mine were easy enough to get off with my fingers.
Then I simply clamped it down and cut off 1.25 inches from the bottom, leaving only the top part.
This cut is solely up to you, it is certainly possible to rough cut it and make it work just as well.
Then it was as simple as putting it back on the post.
Unfortunately it wasn’t that easy… The knob has a hole through the whole thing; however, it wasn’t threaded through the whole thing.
What I did was screw it back on with my fingers and then took a pliers to screw it to the desired height.
The image is hard to see, but the bottom is scuffed up from the pliers; however, this is irreverent due to the fact that it will not be seen.
It was as simple as putting the door panel on to verify the height of the knob and do follow-up adjustments.
The final step was to put the door panel back on.
Here is a picture of what it looks like unlocked:
Here is a picture of what it looks like locked:
I chose to do it this way because I generally drive with the doors unlocked; thus keeping the knob flush with the rest of the door.
The only time it will be inverted in the door is when I am gone and the car is locked.
Yea I think you went too low, you should have done it like BMWs... When its locked, its flush and when its unlocked, there is some sticking out of the top.
Ackniculous One
I drive with my doors locked all the time, so I would love to make mine be flushed with the red line when LOCKED. That way, it's still flush and you can still grab on to it a little in case of emergency. Or, I can leave it the way it is..the door panels irritate me when I have to remove them and put them back on
Broke college grad
i definitely agree with the idea of cutting them down i have the same dilemma with my arm but im with cjitty would be perfect on that red line.
pwnage
1 Post
Taking the door panel off is really a lot easier then it sounds. I was iffy about it at first too but after installing the door handle LED's and having to take them off about 343847387 times I could almost do it with me eyes closed now.
I thought this mod was a very good idea cuz i like to drive with my arm on the door but that damn knob hurt when i did so i did the same thing but kept it flush.
all i did was unscrew, cut about one inch off and then rescrewed it on.
i didnt have to remove the door.
literally took me 5 min. I did have to do some forcing with some pliers and a lil piece of rubber to protect the knob.
Thanks for the idea!!!
you dont have to take the door panels off, i can unscrew mine by hand, cut it and screw it back on, theres like 2 inches of screw thread so you have alot of room to play, if you want it higher unscrew, lower than just screw more, try it, much easier than taking off the door panels.
3.2 VTEC
actually, you didn't even need to cut the knob...you just had to forcefully screw it in further like you did...and then if you ever want it back to normal you can unscrew it back...adjustible knobs lol
actually you could do it without even taking the door panel off, just screw it in more from the top...although you could scuff it and you could break it.
mabe just unscrew it, make the thread deeper, and screw it back on.
SUPRMN84
10-07-2015 09:46 PM
kixo
09-25-2015 03:07 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
