delay in shifting gears when parking
Usually notice this when parallel parking and going from drive to reverse and vice verca a couple of times. Notice there is a slight delay when changing the gears. This has been happening for over a year now. I did change trans fluid
1.6 seconds is the spec delay in shifting thru N to a gear
Its how the trans works-
more than 2-3 seconds means find the problem- cleaning solenoids is the first step
you are running Honda DW-1 atf? not some bs? right?
Fluid level is BETWEEN THE DOTS at specified temp per owner book- cold, or warm from certain 15 minute drive procedure
free owner book download here -need VIN to register with acura care Acura Owners Site | Exclusive Knowledge, Service, & Benefits
1. Shift C.
2. Pressure A/B. Check the filter at the bottom of the three small pipes. Replace the three O-rings and gasket.
3. Pressure C.
4. Shift cable/attachment out of adjustment/worn.
5. Mainshaft speed sensor.
6. Countershaft speed sensor.
7. ATF temperature sensor.
nyse_19
04-09-2016 02:09 AM
Dr B Smith
11-20-2015 07:46 PM
BluNosr2
11-19-2015 12:37 PM
