D.I.Y. Removing Door Panels & Wood Grain
Old 10-02-2007, 01:32 AM
99TL-p 114K
dvsxlt247's Avatar
Post D.I.Y. Removing Door Panels & Wood Grain
So being that no one in this 2nd gen section has ever done a D.I.Y. for removing the door panels and wood grain on the TL, i just did this myself the other evening and I am pleased to have written up this decent guide for all the other members on this forum, who like me, might be wondering how to remove the door panels and wood grain. I hope everyone will enjoy this.
First i started with the right front door. There are two screws you need to remove before you can begin pulling the door panel away from the door itself. The first Screw is located behind the inside door handle. Remove that. The second screw is located on the side of the arm rest towards the bottom of it.
Take a small flat tip screw driver and wedge it in the gap on the right side of the little circle. Pry the circular flap open. Be careful not to scratch up any of the plastic unless you dont care. Take that screw out.
This screw is fairly deep inside the hole. A magnetic screw driver tip helps to pull the screw out of that hole after unscrewing it completely.
Now that you have both of those screws out, remove the triangular plastic black piece from the bottom left corner of your window. Try to get behind it with something so that you can pop it out. Be careful not to break the plastic piece that is attached inbetween the two metal prongs that hold that triangle piece on.
Now begin to pull on the door panel starting from the bottom and working your way up on both sides. Get your fingers under the panel at the bottom and pull on the panel in the middle at the bottom until you hear the sound of the white clip poping out of the slot. The pic below shows where all the white plug in clips are at behind the door panel. Dont be afraid to pull hard enough to get it to pop out. You wont break anything. Here is what the white plug in clips look like that you are pulling out...
After getting all the clip poped out by pulling on the panel all the way around on bottom and both sides, your gona need to detach the cables for the power windows, power locks, and led light and also a spot where they attach the wire to the panel which can be seen in the red circle area with the arrow in the pic down below. You also need to pop the door hanle piece out and detach the metal rod from the handle thats behind the door panel. You'll see what i mean and figure it out when you do this.
Now that you have detached all that, you will be able to remove the panel away from the door completely and set it upsidedown.
On the back side of the panel you will see where the wood grain piece is attached to the panel with plastic rivots, which are basically plastic pieces that have been melted to the wood grain atachment points. Because of this, you will have to drill out the the plastic rivots with either a drill and drill bit or you can actually do it by hand with just a drill bit, but it will take you wayy longer.
As you begin to drill, drill slowly, not fast because you dont want the drill to catch and slam through the plastic and drill through your wood grain. Drill nice and easy applying enough pressure to get through the thin layer of plastic until the drill pokes through and the wood grain becomes loose on that one particular point. You will know when it is.
Here is what you gotta be careful not to drill too much into. Its ok to drill into it though because its gona get smushed and what not as you drill through, just dont go too far or else you gona destroy the entire nipple on the connection point of the wood grain.
Now that you have one wood grain piece out, your going to do the same process to the back door panels and the same drilling process to get the wood grain out. The back door panels are a little harder to get your fingers behind the edge of the panel to pull the clips out all the way around. There is also only one cable to disconnect and thats for the power window swtich.
Once you get to the driver side front door, your going to remove the panel the same way as the passenger front one, except your going to have to disconnect more cabels. You have to disconnect the cable for the power windows, power locks, security light, trunk switch, LED light. There are also two spots on the backside of the panel where they attach the length of the cable to the panel. Just pull those out. Once you have finished the fourth panel, now you will have all the wood grains out and can do whatever you want with them. The Center Console Wood grains are easiest to remove also, most people know how to take those out. Lift the arm rest up, and lift up on the ends of the wood grains that are right by the arm rest and each one will pop out, then just continue to lift following it all the way down to the other end. DONE.
Hope this can be a help for many.
webmastir (03-12-2012)
Old 10-02-2007, 01:37 AM
B A N N E D
Lo Pan's Avatar
damn it, if only i saw this 8 hours ago. i had to mask off my wood trim and speakers
great stuff though man. thanks for your time and effort into putting up a great DIY.
Old 10-02-2007, 01:55 AM
99TL-p 114K
dvsxlt247's Avatar
Yes yes, thank you. One of my finer contributions to this community.
Old 10-02-2007, 07:39 AM
99TL-p 114K
dvsxlt247's Avatar
wonder if i need to post this in the DIY thread also.
Old 10-02-2007, 08:12 AM
B A N N E D
datzdaboi's Avatar
Great write up and post this in the DIY thread
Old 10-02-2007, 08:33 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Old 10-04-2007, 03:33 PM
pnthr30's Avatar
Nice write up....any pics of it with the woodgrain off?
Old 10-04-2007, 05:36 PM
99TL-p 114K
dvsxlt247's Avatar
There is a pic of the panel with the wood grain off. Go back and look at the pictures again. Theres a pic of the panel lying on the blue blanket and i have the wood grain piece flipped upside down ontop of the panel so you can see where it was at.
Old 10-04-2007, 05:42 PM
deal with it
dreem1er's Avatar
very nice diy, but why did you remove the trim, are you planing paint?
Old 10-04-2007, 06:26 PM
99TL-p 114K
dvsxlt247's Avatar
Yup! Hopefully im getting them back tonight finished.
Old 10-04-2007, 06:29 PM
myTaLizaS3.2's Avatar
nice
Old 10-04-2007, 07:13 PM
deal with it
dreem1er's Avatar
ssm?
Old 10-04-2007, 07:25 PM
99TL-p 114K
dvsxlt247's Avatar
ssm?
BINGO!! Im excited. Like i said, HOPEFULLY i get them back tonight. I cant stand driving without my panels in becase its so noisy inside my car when im driving since i have my panels off. Like riding in a metal shell lol.
Old 10-04-2007, 07:31 PM
deal with it
dreem1er's Avatar
i wanted to do the same with AM, but i think the color won't look good against the black interior, so i have an extra set of center console trim to see how it would look.......either way can't wait to see the pics....
Old 10-04-2007, 08:27 PM
BAPE head's Avatar
i did the same thing too....i dropped off my panelsto be painted along with my front bumper. i post up pics when i am done too.
Old 10-05-2007, 05:28 PM
deal with it
dreem1er's Avatar
pics
Old 10-05-2007, 07:28 PM
99TL-p 114K
dvsxlt247's Avatar
Arrow
pics
Nope, no pics yet. Havent gotten them back yet. Im now hopeing to get them back maybe tommorow, my friends shop has been a lil crazy lately and he hasnt been able to fit my small job in, but he does wana get it done asap. So as soon as i get them back, ill put them in, and take pics. Im really excited, kills me to have to wait, but hes doin me a major favor.
Also, My wheels with tires are up for sale. See the link in my signature below for more details.
Old 10-05-2007, 11:24 PM
T-Swzy
Razzi's Avatar
one question, if i remove the white plastic thing that looks like a bag? is my window right behind it? cause i think there's a lot of moisture stuck in my window slot, it squeaks when i roll it and it rolls real slowly
Old 10-07-2007, 03:09 PM
deal with it
dreem1er's Avatar
deal with it
dreem1er's Avatar
is your friend willing to do me a favor....
Old 10-07-2007, 05:22 PM
99TL-p 114K
dvsxlt247's Avatar
Nah, i used to work with him until recently. Thats why hes doin me a favor. Hes painting my wood grains and my B pillars. And then after that, ill show it to this other member that lives near me thats on this forum and if he likes it, then he might have my friend paint his also, but it will be for money. Wait till i have pics and if you like it, then maybe you can talk to him about a price etc. Not sure what he would actually charge for that type stuff.
Old 10-07-2007, 05:24 PM
99TL-p 114K
dvsxlt247's Avatar
to be honest, i dont know whats behind that white plastic. But from the looks of it, i would imagine that the glass is behind that inside the hollow space of the door.
Old 12-06-2007, 09:27 PM
Punctuation Nazi
asujosh1's Avatar
So, how do you re-attach the wood grain panels once you have drilled them out? I would like to do the same thing, but am concerned about re-installation.
Do you just use some short wood or sheetmetal screws with a large flat head?
Old 12-06-2007, 10:35 PM
BAPE head's Avatar
hmm..i have heard of people screwing them back in but i just Rhino glued them in and clamped them in place. Drove without the panels for a whole day until the Rhino glue set.
it was Crazy Noisy.
Old 12-09-2007, 09:55 AM
99TL-p 114K
dvsxlt247's Avatar
You have to glue the wood grains back into the panels. Im going to use some really high grade epoxy, they aint gona go no where lol.
Old 12-09-2007, 10:17 AM
acutee's Avatar
Great DIY.
Old 01-22-2008, 05:28 PM
8th Gear
loksmith's Avatar
awesome thanks!
Old 04-15-2008, 08:10 AM
DECEPTICON
SBUtypeS's Avatar
update?...any pics?
Old 10-07-2008, 01:28 AM
midookie's Avatar
I wonder if this applies to second gen. CL-S...?
Old 10-07-2008, 12:23 PM
Just chillen..
FL3.2TL's Avatar
Should be the same, open it and try it. The only way to find out!
Old 10-09-2008, 06:48 AM
chrismeoli's Avatar
i cant wait to see pics, i have been thinking about doing this forever! any updates yet? How much do you think is reasonable for an autobody shop to charge to paint it all to match the exterior?
Old 10-09-2008, 07:16 AM
fsttyms1's Avatar
You should be able to do it for 20-30 bucks with a spray can and have it look really good.
Old 10-09-2008, 08:41 AM
chrismeoli's Avatar
duplicolor and clear coat?
Old 06-02-2009, 04:20 AM
baddbenny's Avatar
what ever happened to the pics? And Im curious on the reinstall of the panels as well.. Not too keene on gluing them down...alternatives?
Old 07-13-2010, 06:12 PM
xabiostayler's Avatar
Nice post i was able to finally remove my grampa looking wood trims and painted them silver. I have them drying right now ill post some pics when im done..... Great post!
Old 03-09-2011, 01:06 PM
DilnSnu's Avatar
Old 03-09-2011, 04:41 PM
VIP TL
cdn_rider's Avatar
lol nice bump, but are there any actual pictures of this anywhere?
Old 02-20-2012, 03:25 PM
TL202's Avatar
im not sure if i missed it in the reading but how did you reattach the wood trim piece to the door panel...im getting ready to do all the wood trim flat black and was wondering about how to reattach it????
great post btw, very thankful
Old 03-12-2012, 06:02 PM
MattCroissant's Avatar
This thread just saved me so much time. Hayne's manual was trying to make me do so much more!
Old 03-12-2012, 06:40 PM
fsttyms1's Avatar
I used a 5 min epoxy. Just fill the holes that you drilled out with the wood back in place. It will bond it. I did that when i swapped the upper half of the door panels
TL202 (08-18-2012)
Quick Reply: D.I.Y. Removing Door Panels & Wood Grain
