Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003)
Reload this Page >
crank pulley removal tool 0, crank pulley bolt 1 touche
Notices
Old 11-17-2010, 03:58 PM
2000 acura tl FPR
assclown's Avatar
Liked 57 Times in 49 Posts
so yeah. trying to remove my cam and crank sensors on my spare engine, i got stuck at the crank pulley part. this thing does not want to loosen!
so i'm guessing i'll just buy new sensors. grrrr. considering i have a UR pulley on the engine in my car and it hasn't been on very long, it shouldn't be too hard to remove. just thought i'd show you something funny.
assclown is offline
Old 11-17-2010, 05:44 PM
Registered Member
ChucksCL-S's Avatar
Liked 4 Times in 4 Posts
I had to torch it to nearly red hot and then use a six foot pipe on my breaker bar to get it loose. Some guys use a 3/4 impact gun, others use the starter motor method.
ChucksCL-S is offline
Old 11-17-2010, 05:49 PM
ScoobyZINE
AMUA6's Avatar
Liked 41 Times in 38 Posts
AutoZone is gonna have your ass!
AMUA6 is offline
Old 11-17-2010, 06:00 PM
2000 acura tl FPR
assclown's Avatar
never heard of the torch method. i used my floor jack handle (i think it's 4ft long) i have a compressor but no impact guns. no starter method here, this is a spare engine that sits in my back yard.
haha, it's mine. i paid $30 on ebay for it. it worked at least once on my j32a2 engine. the second time around it got warped
assclown is offline
Old 11-17-2010, 06:26 PM
rockstar143's Avatar
Liked 14,644 Times in 10,912 Posts
6 foot breaker bar will be better...and maybe some PB blaster as it's been sitting, no?
rockstar143 is offline
Old 11-17-2010, 07:49 PM
Registered Member
ChucksCL-S's Avatar
At the factory these are held on with big torque AND locktite.....torch melts the locktite.
Old 11-17-2010, 09:58 PM
Registered Member
DaveS221's Avatar
Liked 3 Times in 3 Posts
jeeeeezzzzzzzz im jus takin it to a shop.
DaveS221 is offline
Old 11-18-2010, 12:32 AM
2000 acura tl FPR
assclown's Avatar
i could always load the engine on the truck and take it to a shop haha. but i've already ordered the parts
assclown is offline
Old 11-18-2010, 08:32 AM
Low and Slow
ryebreadisme's Avatar
Liked 0 Times in 0 Posts
Do you think that's just because it's a cheap ebay one? Those tools are really solid. I have one that I paid ~70.00 for and it's done the job again and again.
ryebreadisme is offline
Old 11-18-2010, 09:31 AM
Registered Member
acutee's Avatar
Liked 56 Times in 48 Posts
The tool looks soft to me. The arm looks long, and it doesnt look like a molded tool. The other brands are made of harden steel or cast iron, either work or break, they dont bend.
acutee is offline
Old 11-18-2010, 10:48 AM
2000 acura tl FPR
assclown's Avatar
that's what i was thinking. it did the job for my a2 engine when i changed the timing belt on it and replaced with a UR crank pulley, but this next one got me.
once this project is finished i'll be looking into better tools, but then again, i have no garage yet, so that'll have to wait.
assclown is offline
Old 12-19-2010, 11:51 PM
ITL
I do my own work.
ITL's Avatar
argh...so I'm in a bind. I've got everything I need to do my timing belt, but cannot get this crank pulley off. I have the UR pulley, so the Honda tool won't work. Any idea how to get it off? I can't seem to get anything to hold the flywheel through the inspection port, and 6mt in gear and brakes applied won't hold the crank either. any ideas?
ITL is offline
Old 12-20-2010, 04:25 PM
2003 TL-p
gold2003tl (90)'s Avatar
Liked 19 Times in 16 Posts
ill be trying out my new harbor freight 3/4 inch, 950 ft/lb impact wrench on this crank pulley bolt with in the next week or two. ITEM # 66984 on harbor freight's website. It has a ton of TQ, breaks lug nuts off in one impact cycle, cheap too.
gold2003tl (90) is offline
Old 12-20-2010, 04:27 PM
Registered Member
acutee's Avatar
Use the Starting method: crank with the car key, and turn it off immediately. You will need to have an impact gun to tighten it. its only 50 bucks at HF.
acutee is offline
Old 12-27-2010, 08:19 PM
Registered Member
Liked 2 Times in 2 Posts
Cranking works
The crank method worked great for me, but you need to be VERY careful to confirm that everything is in place and to only turn on the ignition for a sec.
bill_talbot is offline
Old 12-28-2010, 11:56 AM
WILL PLAY POOL FOR CASH
Black-Balled's Avatar
My local dealer did the pulley/ belts for $100.
Well worth it, IMO.
Black-Balled is offline
Old 12-29-2010, 08:39 PM
Registered Member
DaveS221's Avatar
Well worth it, IMO.
originally i was going to do this but i was convinced by several members that its worth the learning experience and saving the money. yea i paid bout 20 sumthin for a BIG craftsman wrench to do the job, and if it breaks, it will be replaced for free cuz craftsman has that whole warranty thing. plus i enjoy the occasional challenge.
DaveS221 is offline
Old 12-29-2010, 09:03 PM
2000 acura tl FPR
assclown's Avatar
correct me if I'm wrong, craftsman lifetime warranty is only good for handtools.
assclown is offline
Old 12-30-2010, 01:34 AM
Registered Member
DaveS221's Avatar
i believe you are correct. but i got a bigggg socket wrench. it doesn't ratchet or anything, its just one big solid piece. so if it bends or breaks or w/e while doing this im not too worried. plus i had a little leftover on a sears giftcard so it ended up being only 20 sumthin.
DaveS221 is offline
Old 12-30-2010, 01:36 AM
Registered Member
DaveS221's Avatar
main thing going thru my head tho is the starter motor. has anyone ever experienced any damage or explosion or sumthin crazy happening to it? yea explosion may be a little exaggerated but you get my point.
DaveS221 is offline
Old 01-04-2011, 08:42 PM
Registered Member
Removed mine easy with the gun (CP) but then maybe it had already been removed in the past...
nicotls is offline
Old 03-28-2019, 05:10 PM
Registered Member
Liked 75 Times in 62 Posts
Something similar happened to my TL at about 200k miles. The started had died.
schen72 is offline
Old 03-29-2019, 05:13 PM
Registered Member
whitetiger5's Avatar
Liked 17 Times in 17 Posts
whitetiger5 is offline
Old 04-04-2019, 12:19 PM
Registered Member
Liked 18 Times in 17 Posts
Impressive! I should collect my broken tools from my failed attempt at doing this over the past weekend. Broke a few impact sockets, a breaker bar (at the socket joint), the cheater bar, a few extensions.
Heating it didn't work, 1200ft/lb 1/2" drive impact did nothing, 1500ft/lb 3/4" did nothing either. Starter trick didn't work, cheater bar + breaker bar just broke tools, soaking in PB Blaster and torching it all day didn't help either.
We didn't get the bolt red-hot, but I may try doing that later. We decided that after 7 hours of working on the one bolt, that it's torqued on with the will of god himself and that we had no business removing it, LOL
Any other trips from my fellows here on getting that bolt off?
Arkady is offline
Old 04-04-2019, 01:11 PM
Registered Member
Try heating the pulley...It's common to presume heating the bolt, but heating the bolt will make it more difficult to remove as it acts similar to a cylinder which will expand as temperatures increase. After you heated the pulley, perhaps try hitting the BOLT with some freezing spray, then immediately try to remove...
Old 04-04-2019, 01:35 PM
Registered Member
Now there's an idea! Good thinking. My belt looks fine and this was moreso preventative maintenance due to mileage, but I'll give that a shot later this summer when I can afford to take this car apart again. Thanks!
Arkady is offline
cycdaniel
02-26-2019 08:55 AM
Laoch
First Generation RL (1996-2004)
10-02-2015 03:27 PM
mossman77
1G & 2G MDX Discussion (2001-2013)
18
09-16-2015 12:21 PM
CadiGTi
Second Generation RL (2005-2012)
09-14-2015 06:37 PM
iCrap
Second Generation TSX Discussion (2009-2014)
20
09-11-2015 06:21 PM
Quick Reply: crank pulley removal tool 0, crank pulley bolt 1 touche
