coolant drain ??-plug bolt
Where exactly is the coolant drain plug and drain bolt. P. 241 doesn't help. I can't seem to find it.
right side, left side?
Also shall i use honda coolant?
The coolant drain plug should be on the bottom passenger side, or middle of the radiator. I'm not sure, but this is where Honda usually puts them from previous experience.
I personally like to use Honda Pre-mix because it contains distilled water. Though, you could buy distilled water from the grocery store, and mix 50/50 with your favorite type of coolant.
Don't use regular tap water because it contains lots of crap (chlorine and other minerals) which will eventually clog the radiator core. Consider this a cheap investment.
MetalGearTypeS
08-29-2016 08:28 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
