Changing D5 bulb in gauge cluster
Old 03-13-2011, 01:36 AM
Unregistered Member
Karanx7's Avatar
Hey guys, I've read a couple threads about D5/D4 bulbs burning out. I installed some reverse glow gauges, and my D5 and 2/3 odometer bulbs burned out (coincidence?). I haven't really read any complete DIYs for changing the D5 bulb.
When I was installing the glow gauges, I also forgot to put in the 4 screws for the gauge cluster. I figured I would take care of both, so I attempted to change the D5 bulb. With some help from my.daily'tl', I successfully changed it. It wasn't that hard, but there's definitely potential of damaging the cluster if your not careful. If anyone still needs a DIY for changing it, I'll write one up and take pics. Maybe I'll just do a video?
Also, I forgot to put in the 4 screws again.
Old 03-13-2011, 02:03 PM
dc2kid's Avatar
hey can you post a diy or a video thanks
Old 03-14-2011, 03:58 AM
Unregistered Member
Karanx7's Avatar
I'll make a video when I take it out again to replace my ODO bulbs. Might be a couple weeks until I get my kit from www.ledautomotive.com
Hopefully I'll actually put the 4 cluster screws back this time.
Old 03-15-2011, 03:08 AM
Unregistered Member
Karanx7's Avatar
Follow up Q:
Can someone test something for me? When your driving along in D5 and you shift into Sequential SportShift, does your D5 light in the cluster turn off? Mine stays on, and I could swear I remember it turning off when switching to the shift mode.
Also, is it supposed to be fairly difficult to shift into that mode? All my other cars do it seamlessly, but my Acura shift knob needs a solid jolt to the left.
Old 03-15-2011, 11:15 AM
niju321's Avatar
i have a 99, so i only have a D4 light, but i can confirm that it does stay on when in sportshift. and i have to give the shifter a pretty solid thwack as well.
Old 03-16-2011, 11:46 AM
Severin's Avatar
Originally Posted by Karanx7
Follow up Q:
I'll check tonight. As for the "jolt" to the left, did you ever have your transmission replaced? If so, it is very possible they never readjusted the shifter. Iit may not be properly aligned with the gate and will take considerable force to go into sports shift position. Once in the right alignment, it should move quite easily.
Old 06-02-2011, 11:30 AM
6th Gear
dsmaniac's Avatar
Any updates on some pics of the D5 bulb change? Need to get it done for MD inspection, thanks.
Old 06-02-2011, 12:42 PM
Severin's Avatar
I have the bulb, but was going to wait a few more weeks before I attempt it. I have the service manual and it looks straight forward.
I just have to figure out how to remove the top cover off the steering column without breaking it.
Old 06-02-2011, 01:06 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
3 screws from underneath
Old 06-02-2011, 01:29 PM
Unregistered Member
Karanx7's Avatar
Service manual won't help at all with the cluster disassembling. I posted a write up on the CL side. Let me find it.
Old 06-02-2011, 01:32 PM
Unregistered Member
Karanx7's Avatar
If you have experience with the cluster, this replacement should be a cakewalk. Just disassemble the cluster as you normally would. When you get to the gauge faces, you need to remove them. Bend the metal tabs on the back side of the cluster up. That will allow the gauge faces (along with the needles) to fall out. Then, you will have to separate the front half of the gauge from the back half. There are two clips in the centerish part of the gauge. You will need to release them from the gauge. Now you will have a fully disassembled gauge with the D5 bulb right in front of you. Just count down from P, N, R, D5 from the top. Remove that bulb by pulling it straight up (away from the gauge). Do NOT twist it. The bulb should be dead/black. Here's my tip. Remove the D1 bulb, and put it in the D5 bulb spot. If you have a new bulb, put it in the D1 bulb spot. That way, you won't have to worry about a bad bulb. Also, the D1 bulb should be in great shape anyway. How often do you gate shift or tow stuff?
Follow this guide until it gets to the part about removing the regular bulbs:
http://ledautomotive.com/guide.php?id_cms=52
At the end of that guide, you will have your gauge faces off the cluster. Now all you need to do is remove the front half of the cluster from the back half. This is where the part with the two centerish clips come in to play.
Good Luck
Old 06-02-2011, 01:35 PM
Unregistered Member
Karanx7's Avatar
Here is a guide to actually get to the cluster itself:
http://ledautomotive.com/guide.php?id_cms=49
vejaco (12-18-2017)
Old 06-02-2011, 02:34 PM
Severin's Avatar
Thanks!!
Old 06-02-2011, 02:52 PM
6th Gear
dsmaniac's Avatar
Thanks a lot, that was very helpful. Do you happen to know where to get replacement bulbs for the gear selection or is the only option to buy a the LED kit?
Old 06-02-2011, 05:30 PM
Unregistered Member
Karanx7's Avatar
^ You can buy the bulb from Honda. It's kind of a rip off for a single bulb (something like ~6 dollars).
I'd recommend just swapping the D1 bulb with the burnt D5 bulb. You're probably not going to be using D1 very often, so I don't think you would notice.
Old 02-20-2014, 07:27 PM
dan1995's Avatar
Change D5 bulb, TL 2001, could not remove the old bulb
Hi Kanranx7, I was be able to fully disassemble gauge with the row of gear bulbs in front of me, but I could not remove the bulb, any one of them. Each bulb is in the tiny cubical box. How did you take them out? I know this pretty old thread. Thanks for the help.
Old 02-21-2014, 12:08 AM
Unregistered Member
Karanx7's Avatar
Take a picture so I know you are on the right layer of the cluster.
If you get directly to the bulbs, they just slide off and on.
Most likely you still need to remove the green PCB from the front white housing. To do that, just look at the back of the cluster (should just be a green PCB). You will see like 2-3 white tabs sticking out that will release the PCB from the front housing.
dan1995 (02-21-2014)
Old 02-21-2014, 09:31 AM
dan1995's Avatar
Wow!!! Thank you for your fast response. I thought this thread is retired like me.... I'll try to do it again today. I think I have to separate the outer back board (A) after removed the gauges' faces and needles (?) I missed this step, how silly I am...I'll post the results. Again many thanks.
Old 02-21-2014, 11:16 AM
dan1995's Avatar
I successfully removed the green PCB from the front white housing. The row of those bulbs are in front of me but I still can not figure out how to take a bulb out since I don't want to break it, is it soldered to the board? Does it have a socket like the others?
Old 02-21-2014, 11:28 AM
dan1995's Avatar
"If you get directly to the bulbs, they just slide off and on."
Is it how to remove the bulb? Can you show me in detail?
Old 02-21-2014, 12:42 PM
Unregistered Member
Karanx7's Avatar
The bulbs are attached to the PCB by a rubber piece that just slides off two pins.
Just take a pair of pliers and gently pull them straight out. If they don't come out, you still have to remove something in front of them.
The pictures you loaded don't work for me, where did you upload them?
Old 02-21-2014, 02:51 PM
dan1995's Avatar
Thanks Karanx7. Finally I removed the D5 and replaced it withe bulb of D1. Since I did not buy a new bulb so I did not know what the bulb's form and fit should be, I assumed it's just like brake, stop or flash light, just insert it in the sockets... but this one is special, it has its base itself.
Again thank you, good work. I'm happy....
I'm new here...the pictures I just embedded/copy them into the message. Don't know other ways, sorry...
Old 11-01-2019, 04:12 PM
9th Gear
WaarrEagle's Avatar
For anyone that stumbles across this thread looking for instructions to change the D5 light, here are some pictures I took today while replacing mine. You can see how the parts have to come apart and what the bulb looks like.
The following 2 users liked this post by WaarrEagle:
Chojun (11-07-2019), simongrewal (11-18-2023)
Old 11-03-2019, 07:48 PM
Unregistered Member
Karanx7's Avatar
Thanks for the pictures!
Silverstead1
09-17-2015 06:45 AM
acuraST
09-17-2015 02:31 AM
brandnewcolony
09-12-2015 10:39 AM
SpraykwoN
ILX
09-11-2015 08:45 PM
Aleax
09-11-2015 11:31 AM
Quick Reply: Changing D5 bulb in gauge cluster
