Car shakes/rattles/shimmy 40-60mph fix!
#41
You do realize that I was responding only to post#27 by neejay. His description of a shake that only happens in the morning when he first gets on the highway, and not later in the day, still sound like tire flatspotting to me. I am referring to the kind that comes from sitting overnight, not from skidding as fsttyms mentioned.
Several bad points on this thread, an alignment can not and will not cause a vibration shimmy or any movement, defective parts do, not the alignment.
Brakes don't sqeak unless they are improperly installed and several other comments about break noise are in left field.
#42
uhmm sorry don't agree with either of you and a tire flat spotting from sitting over night, just doesn't happen, now it might loose a pound or two of air pressure but again that typically doesn't throw the balalnce off.
And yes, brakes CAN squeak when installed properly. Ever hear a race car with cold brakes? Are you going to tell me that they installed the pads wrong? Why do you think they put shim plates and anti squeal on pads
#43
typically if they are squeaking it's because the outside pad is not tight to the caliber. Carbon brakes a race car may use are a totally different animal.
#44
Tire rack's website has info on tire flatspotting if you are interested.
#45
Having the outside pad tight to the caliper is typical on many domestic cars, but many imports use grease and/or shims to let the pads move somewhat freely in the caliper. There are many more causes than improper installation that cause pad squeal. I've never seen a tsb on brake noise that lists improper assembly as a cause. I won't argue that many times squeal comes after a sloppy install, just not always.
the shims are not needed to start with and will not prevent any thing and will on create additional noise, the grease is for the self adjusting feature of the caliber. On The tl style caliber, if the retainers are bent worn or not installed correctly then the pads sqeak, the older style brake calibers the outter pad is clamped on basicly, newer style use a retainer system that is basiclly a fancy spring as the pad is held be two ears on the pad in a groove in the caliber.
Flat spotting tire please it would have to rewrite the laws of physics and plastic deformation. So I don't agree with the BS that a car sitting over night or even for a couple of days is going to temperarerly flat spot a tire, now have an under inflatted tire and leave the car sit for a month or two yes that will cause permiment damage to the cords internal to the tire and create a problem but don;t feel that is the case here.
#46
UUUHHHMMMM sorry
Also whats your excuse for "floating pads"? I have heard them squeal. Kinda hard to install them wrong since they just drop into place and float in the caliper. Brakes Can and do squeak, even with "proper" installation.
I guess the experts are all wrong, or have re-written the laws of physics.
Read this and tell us we are still wrong!
http://www.tirerack.com/tires/tirete...jsp?techid=42&
#47
Kinda hard to take anyone seriously that is debating brakes with others when they dont know its a CALIPER, not a CALIBER.
Ever notice the bosses on the back of the brake pads what are those for hold them in place against the caliper, or why they sell brake hardware kits, replace the brakes you need to replace the retainer too otherwisse your floating pads will sqeak because the dumb ass that install them didn't replace the old worn out retainer.
#49
UUUHHHMMMM sorry
#50
WELL I GUESS my spelling is as poor as your reading skills that pretty much backed up what I stated. Said yes you let them sit long enough they will flat spot maybe you missed all the variables they listed.
have been parked overnight in cold temperatures, or parked for an extended period of time...
#51
Guess you cant read either and missed the
Have you ever seen a set of top load 2 and 4 piston calipers? Have you ever changed pads on them? You pull a pin out, and pull the pads out, compress the pistons, and "drop" the pads in and slide the pin back in to hold them in so they dont come out. There are NO bosses that hold them in place, no retainers, they float.
#52
hopefully someone can help me out. here is my problem. My car shakes/shudders (forward/back movement, feels bunch of air pockets in the engine causing it to move back and forth) when i reach 50-60 miles per hour. Both happens in 4th and 5th gear. Also, it only happens if gas pedal is stepped on lightly and held at a certain point. reading the notes above, seems like an axle issue but we check the boot and axle, there was no grease or tears visible. Advise?
Here are some possibilities that my friends told me:
1) axle
2) idle control valve
3) ECU
4) engine mounts
5) recently had TB/IM spacers and p2r plenums installed, maybe a missed hose connection? wrong install?
1) axle
3) ECU
4) engine mounts
#53
anyone?
1) axle
3) ECU
4) engine mounts
1) axle
3) ECU
4) engine mounts
#54
now the most popular car shake/shimmy
4. IF CAR SHAKES/RATTLES WHILE ACCELERATING ANYWHERE AROUND 40-60MPH
CAUSE: BAD. HORRIBLE. BENT. WARPED. IF NOT CRACKED AND ALMOST BROKEN AXLES!
sorry to say, but thats what it is. its your axles.
how do i know this?
because i did everything from, new tires-> tire balance->tire swap->allignment-> new coilvers-> allignment->tire balance->new side engine mount->replace axles->return engine mount
finally, the shaking is gone.
just go buy aftermarket axles, oem and aftermarket are SAME EXACT THING, packaging is different, the logo is different, and the box has basically no design whatsoever. thats 60% discount for you.
rebuilt axles run around $30-40. new aftermarket runs around $60-80 each. replace both of them!
and enjoy the smooth ride, just like it how it was when you first drove the car
enjoy!
I really dont understand why dealers and maniacs cant diagnose problems anymore, even logical ones like this...
#55
1) axle
3) ECU
4) engine mounts
1) axle
3) ECU
4) engine mounts
#56
Wow, i just had all my motor mounts replaced (from junk urethane) and my 04 TL started vibrating at 40-60mph. I got suggestions from tires, rims, torque converter to throttle body. IMO it was the Axel, but no one really thought that's what it was. Thanks for the more probable confirmation!
The key confirmation was when we had it up on the rack we put it up to 50mph and no shaking, but apply some breaks and the motor shook like crazy.
#58
While it's possible that the driveshaft axles are causing the problems due to worn splines or joints......there are other simple things that should be ruled out first, IMO.
Tires that are out of round or improperly balanced, along with untrue rims are the first place to check, then brakes....steering....suspension components all need evaluated.
#59
However a very detailed list of what makes the problem A instead of B can be very helpful. For example radiofred doesn't seem to have all the exact issues I had and he should look at tires rims steering components first like you say.
#60
Since your symptom's aren't exzacley like mine then no, its probubly not the Axles.
#61
Shimmy/shakes
Ive had many rims and tires on the the car with the same effect, I have brand new CCW rims and falken tires, brakes/rotors are brand new, I'm lowered on BC racing coilovers with air cups, brand new upper control arms, sway bar links, and a fresh alignment the car is very low but it did it before I had lowered it the only time I noticed it did it the least was when I was on corvette saw blade rims
#62
Check all the lower end suspension/steering components.
Are the LBJ, WB, control & trailing arm's bushings, tie rod ends, drive shafts & etc. all tight ?
If ya are really low....these parts take a beating !!!!
#63
1996 Buick Regal
My car faithfully shakes/shimmy's every time I reach 40 mph. I just put new break pads front/rear and replaced rotors and calipers, rear. My car did not shake/shimmy til after I fixed my breaks....the work was done by a trustworthy mechanic with 30 years experience. He says my wheels need aligned.... The tire shop says they don't???? A friend of mine says its the tie rod? I have very little knowledge of cars so any advice would be greatly appreciated!!! Again, once I reach 40mph my car shimmies and shakes, when I reach 50 it levels out and rides great....?????
#64
high speed shaking
I have an 03 Acura TLS and when I am doing 120 - 130 km it starts to shake/lose power - I don't see the RPMS drop at all but it is like the car just "dies" for a second, I have had a tune up done on it, transmission fluid is fine etc. so I am at a loss as to what it could be - any ideas? Never had this problem with my Nissan Titan!
Thanks!
Thanks!
#65
2003 RSX shutter
In automatic if I'm doing 40-45 mph and let off the gas or I am barely pressing the gas the car shakes back and forth for a few seconds. In manual it doesn't do it. But the car shifts up and down fine in both setting. Any ideas?
#66
Once I went on vacation and my car sat in a lot for about five days, in very cold weather. Went I got back and pulled onto the freeway, the shaking was severe for a bit, then went away. Very annoying. I thought something was wrong with the car at first.
#67
https://acurazine.com/forums/tires-w...cement-934708/
Originally Posted by rcb2000
I would say your just a tool that has never been paid to fix someone's car for a living asshole. And since when do you have to jack with the intake when dealing with the front suspension dick.
#68
You sound like you have a lot of experience with Acura's. Having repeated problems with inside tire wear on the front of my son's 2001 cl type S automatic. Factory rims and spring height. Any suggestions? Have it aligned by an Acura dealer will be our next move.
#69
04 6 speed.. 156k original owner Just replaced with OEM ..mid axle and still have vibration between 60-65 ... I spent over 700.00 on this problem now and still no solution .. : ( I happens under torque more than on level surfaces ..
HELP !
HELP !
#70
If you went to a shop and they quoted you $700 to fix the problem, I would go ask them to re-diagnose and deeply discount the work they didn't catch the first time. Its most likely a bent rim, brake rotor, or even the new axle is off balance.
