Notices
Brake line replacement
Old 11-19-2018, 05:30 PM
Registered Member
Liked 0 Times in 0 Posts
Hi all, I have a 2003 Acura TL. I was driving home the other day and noticed I had to press really hard on the brakes to stop the car. So I got home and checked the car out and noticed there wasnít much pressure I the brakes. So I looked into the resistor of the master cylinder and it was empty. I found the leak On drivers side rear right where it goes up by the fuel tank. The leak is on the long horizontal line that goes from front to rear. I canít get the black cover off. Anyone know how to get off? I was ready to rip the dam thing off.
Acuratl3535 is offline
Old 11-20-2018, 06:26 AM
Registered Member
Liked 154 Times in 127 Posts
That first pic looks like those 2 tabs are holding it in on that end and you should be able to depress release and it would pop off. Not sure how other end is affixed
08KBP_VA is offline
Old 11-26-2018, 06:19 PM
Registered Member
Finally replaced the brake line that had a pinhole. Now itís time to bleed brake system. Since the master cylinder was empty do I need to bleed it? Also the employee at advanced auto recommended Valvoline dot 3/4 brake fluid. Never heard of it, is it ok to use? He said it was compatible with dot 3 or 4. Thank tou
Old 11-27-2018, 06:50 AM
Registered Member
Yes you will need to bench bleed the master cylinder, well I would then pressure bleed the 4 corners. I believe thats the same I used on all my cars even my performance sedans.
08KBP_VA is offline
Old 01-24-2019, 05:34 PM
Registered Member
Liked 2 Times in 1 Post
My 2002 TL-S brake line leaked. I took it to my mechanic who charged me $380 for the work. Is that price too high or ok?
wowzer is offline
Old 01-30-2019, 09:41 AM
Registered Member
Westfallen's Avatar
Liked 2 Times in 2 Posts
Yeah that's way too much.
Westfallen is offline
Old 01-31-2019, 10:37 AM
Registered Member
The mechanic said something about 2 locations breaking (he tried to tell me exactly what but I was too busy on a second call and missed the technical parts, just heard that 2 lines had to be replaced). I saw on the ground that I had 2 spots where brake fluid spilled....could that account for the higher cost?
wowzer is offline
Old 02-02-2019, 09:57 AM
Registered Member
Liked 225 Times in 190 Posts
It sounds to me like you needed at least two brake lines. Based on that, along with typically having to un-seize bleeders, and flush and bleed the system, it sounds reasonable to me. Generally the job involves splicing in steel or copper/nickel line rather than replacing factory made pre-formed pieces. This consists of double or bubble flaring up to four fittings per spliced line, so it can be time intensive.
I'm recently retired, 45 years as a mechanic and shop owner.
TLer trash is offline
jdmjess
07-03-2016 09:45 AM
Bearcat94
Third Generation TL (2004-2008)
19
06-15-2016 08:32 AM
Joberube
07-18-2013 10:32 PM
sweettl04
07-27-2010 05:05 PM
Jeanius
19
02-09-2007 10:02 PM
Quick Reply: Brake line replacement
