Brake Caliper Bracket Mounting Bolt Size? - AcuraZine - Acura Enthusiast Community
Notices
Old 01-08-2019, 10:24 PM
New Member
Question Brake Caliper Bracket Mounting Bolt Size?
need to know the size of the caliper bracket mounting bolt
Was doing all 4 wheels pads and rotors and ended up rounding one of the rear brake caliper bracket mounting bolts does anybody know what size bolt/thread it is? I think its 14mm just don't know how long it needs to be. Can't find a replacement at any auto parts stores in my area and haven't had any luck online either. I have a snip of the part but it only has the torque spec to clarify NOT THE BOLTS FOR THE CALIPER PINS
2003_tl_200k+ is offline
Old 01-08-2019, 10:36 PM
Registered Member
Look at line item #17 on the link below for its size:
https://www.oemacuraparts.com/v-2003...s--front-brake
zeta is offline
The Following User Says Thank You to zeta For This Useful Post:
2003_tl_200k+ (01-08-2019)
Old 01-08-2019, 10:44 PM
New Member
It says it fits the year so worth a shot thanks!
Old 01-09-2019, 08:25 AM
Registered Member
Iggy's Avatar
This metric flanged bolt has a thread pitch of M12x1.25, and is 21 mm long (thread length, measured under the head to the end of the bolt). The entire length, including the head, is 32.2mm. The hex head requires a 17mm socket for removal/installation. The bolt grade is 10
Iggy is offline
binary_10essee
Second Generation TL (1999-2003)
34
07-21-2017 12:42 PM
paulmnly
12-02-2014 12:53 AM
acitydweller
10-29-2007 10:33 PM
bojangling
2G CL Problems & Fixes
08-17-2007 05:21 PM
mcfarlektsx
08-29-2006 01:27 PM
Quick Reply: Brake Caliper Bracket Mounting Bolt Size?
