anyone ever try Seafoam Trans-tune?
Considering our trans arent like most i dont know if i would.
I was a little hesitant too, saw it sitting there, and I know how respected the regular Sea-foam is. Anybody want to give it a shot? Maybe I wll be the brave one, I am planning on a trans fluid change soon. It says to use it roughly 100 miles before you change the fluid and it will give it real good clean out.
Kilos of yayo in
I would not use it unless you did a complete flush and that is not even recommended for acura transmissions. If you do a drain and fill after using this stuff there will still be alot of it still in the tranny. You could do a few drain and fills but I don't know how much I would trust that since I am pretty sure the bottle warns you to get as much of the product out of the transmission as possible. Despite all that if you have a different car that is a bit older it might help. I did it on my 96 ford ranger and it did seem to shift a little smoother at that point. I would not use it on the Acura though, just my .
acuratl26
04-23-2020 07:30 PM
EPS CL
06-02-2009 11:16 PM
manteuffel
03-12-2006 11:12 PM
