Anybody Used Monroe Struts on their TL?
Been thinking about replacing the struts on my 2000 TL for some time now especially since they have the original factory struts with over 270K on them. I know OEM Honda struts are damn near bullet proof and the original ones that are on the car aren't too bad. I'm not noticing an overly bouncy ride or bad tire wear but the fronts are squeaking badly when they bounce so I figured after all this time its probably best to replace the struts and mounts to keep my suspension in tip top shape.
I've been thinking about using Monroe struts since they're the easiest struts for me to get and are the lowest cost with a lifetime warranty, but before I pull the trigger I wanna know if any of you guys have experience using Monroe struts on your TL's or if I should spend more on KYB's or something? Or hell if it's even worth replacing the ancient OEM ones in the first place? |
I got Monroe quick struts for my wife's Honda Element and they worked fine.
For my 2000 3.2TL I got some Ebay quick struts. They were serviceable but made noises. Eventually I bought some higher quality shocks and a spring compressor and swapped them in to my original strut assemblies. Since the strut assemblies were already out of the car, I could do it at my leisure, rather than being in a hurry. That was several years ago. At the time Monroe did not make quick struts for the TL. |
Originally Posted by murky
(Post 16430790)
For my 2000 3.2TL I got some Ebay quick struts. They were serviceable but made noises. At the time Monroe did not make quick struts for the TL. I recently just replaced both inner and outer tie rods that were also original and man the steering feel is so much better now. |
I got KYB Excels Gs and they ride a little stiffer than OEM but feels very solid ... Got them off Rockauto.
I replaced all mine with kyb g2 struts. One of the fronts blew out, but was replaced under warranty. Besides that, they are a dream to what was on there before
Did you confirm that it was the struts that were squeaking? a lot of the time it ends up being Ball joints or end links; there are many more of those.
If you do end up changing out the struts I would highly recommend also changing out the rubber strut bushings as well as the spring top hat rubber. |
Originally Posted by Mickeyreategui
(Post 16438186)
+1 to KYB. Awesome OEM quality ride for a fraction of OEM cost. |
