AMSOIL switch over questions
Old 04-13-2013, 09:54 AM
cb2honk's Avatar
I just bought a 02 Acura TL with 86,000 miles on it from the original owners, who are 72 years old, $5,200. The car is immaculate! They had every service record from day one at the dealership they bought it from. I am really nervous about the tranny...at 26,000 miles the dealer installed some fluid/oil jet on the tranny after they inspected it and determined the tranny was in good condition. The tranny has never been replaced. But, as far as I can tell driving it the last week, it shifts great and runs great.
Now for my questions. I want to switch the engine oil over to Amsoil signature series 5w20 and the amsoil oil filter. I don't know what amsoil filter part I need to order?? Also, want to start running the AMSOIL ATF fluid, but I see a couple of different options and not sure which one to use?? Should I just do a 3x3 fluid change as explained in posts that I've read on here??
Thanks for all the help.
Old 04-13-2013, 10:36 AM
cb2honk's Avatar
Fogot to ask when you guys are draining the tranny fluid out, does the car have to be level? I'm not sure how to accomplish that in my garage, not sure if I can fit under there without the car on ramps.
Old 04-13-2013, 11:30 AM
3.2TLc's Avatar
Congrats on the low mileage '02 !
It appears as though you're an Amsoil product fan. Their stuff is ok, but some of the top brand synthetics are just as good. The choice is ultimately yours. One thing that may be better to use is the Honda DW1 fluid....which is an improved "oem" synthetic ATF recommended for replacing the original tranny fluid.
You should be able to access the tranny drain bolt rather easily....being level is not a problem, but be careful when first breaking the plug loose. They usually are tight !
Old 04-13-2013, 11:37 AM
cb2honk's Avatar
I had also thought about red line products, that is what I use in my snowmobiles and it has been great.
Old 04-13-2013, 11:50 AM
3.2TLc's Avatar
Yeah, I actually think that Redline would be a better choice than Amsoil.
But, a bit pricey !
Old 04-13-2013, 08:30 PM
cb2honk's Avatar
107 views and nobody knows what amsoil oil filter I need, dang. Guess I will have to call them.
Old 04-13-2013, 09:51 PM
3.2TLc's Avatar
Question Amsoil oil filter # ......?
....Amsoil's website more than likely has cross reference product info for their specific filter recommended to replace the TL's regular ones.
Also, if ya want more 'Ziner input on Amsoil, ya can always check some previously posted threads on the subject by simply performing a "Search" !!!!! Try it, ya may get what you need to know quicker that way.
Old 04-14-2013, 03:17 AM
MilwaukeeDave's Avatar
I can tell you which K&N filter to use...
Old 04-14-2013, 12:54 PM
2003 TL-p
gold2003tl (90)'s Avatar
Only use ATF-DW1 from Honda. If this is an original tranny with 86k miles, I wouldn't even touch it, period.
Old 04-14-2013, 09:34 PM
Skirmich's Avatar
Received 1,015 Likes on 866 Posts
Your trans will die... My Amsoil switch didnt last the month until it foamed and puked it.. Use Only Honda DW-1 or Redline Mix
Old 04-15-2013, 07:26 PM
cb2honk's Avatar
redline mix?
What is the K&N filter part# and what oil do you use with it?
Old 04-16-2013, 10:44 PM
'12 & '13 AL West Champs!
Gfaze's Avatar
redline mix?
http://www.knfilters.com/search/appsearch.aspx
Don't be lazy, the internet isn't rocket science.
Old 04-17-2013, 07:47 AM
cb2honk's Avatar
Wow...there are some real pricks on this forum. I don't live on my computer like some of you obviously do. Gfaze, 12,8** posts, you really need to get a life, man, or a job. See you are in the great state of cali, how's the economy out there? More people like you need to spend less time being forum pricks and more time actually working at a JOB! Maybe then, you wouldn't have the rest of the country wishing california would just fall off into the ocean along with all the pricks that live there!
Old 04-17-2013, 09:44 AM
Registered Nonmember
TheMightyQuinn's Avatar
So an anonymous stranger on the internet helps you out by giving you the resources to answer your question, and instead of thanking him you respond by calling him and others on this forum "real pricks" and insult them based on their geographical location?
I'm guessing you routinely got the "does not play well with others" comment your report cards as a kid.
Are all people in your unknown location as entitled and snotty as you?
Thanks for your contribution to the forum, new member cb2honk.
Old 04-17-2013, 10:19 AM
But I just got here
Nitin's Avatar
This link below should list all the info you need for your 2002 TL. Now can the mods please lock this thread and ban the thread starter?
http://www.amsoil.com/mygarage/Vehic...+ACURA+3.2TL+5
cb2honk (04-18-2013)
Old 04-17-2013, 06:14 PM
3.2TLc's Avatar
Question Amsoil ?
Nitin's taken care of ya !
Old 04-18-2013, 02:48 AM
Skirmich's Avatar
Ohh and to Add the K&N Filter is the "HP-1004" hahahaha I Didnt Noticed that question.... And I only use Mobil 1 (EP) "Extended Performance" 5W-30.
Old 04-18-2013, 07:31 AM
cb2honk's Avatar
Skirmich,
Thank you for the helpful input. When you posted to only use DW-1 or redline mix. What did you mean by redline mix? Do you mix DW-1 with redline? Thanks
Old 04-18-2013, 03:48 PM
Skirmich's Avatar
Redline have 2 different ATFs a Normal and a Racing one.. I dont know the exact details on WHY You Mix both but you use a Mix of the Normal ATF and the Racing Formula for the best results...
If somebody who used the Mix or know more about it could chime In to wonder us with Info about it.
Old 04-18-2013, 04:35 PM
TLer trash's Avatar
^^It's 1qt racing, 1qt lightweight racing, and 1qt d4. There are a couple really long threads on the 3rd gen side discussing it.
Old 04-18-2013, 05:14 PM
Skirmich's Avatar
You learn stuff everyday it seems... So its 3 different Quarts...
Old 04-19-2013, 07:31 AM
3.2TLc's Avatar
Thanks for the info, but I'll stick with the recommended Honda "DW1" fluid.
Old 04-19-2013, 09:56 AM
2003 TL-p
^ +1. I have had good results with DW-1.
Old 04-19-2013, 10:14 AM
3.2TLc's Avatar
Yeah, "DW1"...... it's the good stuff !
Why go outta the box for something known to be so critical as our finicky 2nd gen trannys ?
Old 04-19-2013, 10:33 AM
cb2honk's Avatar
Honda has their brand oil, just the same as motorsports manufacturers have their own brand oil. I own dirtbikes, motorcycles, snowmobiles, and through research and many years of trying different oils, it has been proven OEM oil isn't always the best. This is just an example, Polaris sells a gallon jug of their top of the line synthetic 2 stroke oil for nearly $50, and it doesn't come close to Legend Performance or Redline 2 cycle oil. And, it was proven in tests done on multiple oils by an indepent person. That is why I'm interested in something other than OEM oil, not saying DW1 isn't great, just want to make sure I put the best in my car.
Old 04-19-2013, 06:00 PM
2003 TL-p
Transmission fluid is completely different than motor oil.
Honda put specific friction material in the clutch packs of our transmissions. The also designed a fluid to be compatible with that coefficient of friction. This is determined by friction modifiers in the fluid. Thus explains why dumping any old "tranny fluid" will not work in all applications. It doesn't matter as much whether Honda's oil is better or not, the friction properties out-way that. These friction properties must match; use the Honda fluid for that reason. You can blend your own transmission fluid out a mix that contains friction modifiers and non-friction modifiers, but that's guess work. It may or may not work. Some have had success with Redline blends, others have had complete disasters. Stick with DW1 - That's what's best.
The following 2 users liked this post by gold2003tl (90):
3.2TLc (04-20-2013), cb2honk (04-20-2013)
Old 04-19-2013, 06:39 PM
Skirmich's Avatar
Honda knows best... At least with my Amsoil test that led into Puke and almost My trans toast, Honda owns Amsoil and Ill never try the Redline mix soo DW-1 > All.
3.2TLc (04-20-2013)
Old 04-20-2013, 10:29 AM
cb2honk's Avatar
Thanks for the input. Much appreciated!
VA2000TL
10-02-2015 08:26 AM
Fandango12
1/2G MDX (2001-2013)
09-20-2015 05:25 PM
Skirmich
09-15-2015 06:41 PM
datadr
09-12-2015 09:12 PM
MyGuti
09-12-2015 06:52 PM
Quick Reply: AMSOIL switch over questions
