ABS TCS and SRS always on.
Car: 1999 TL.
I did a bulb check last week and I noticed most of them were not working. So this week I pulled out the cluster and they were all gone. PO must have taken them out. Only 2 were functional. So i go to my local junkyard and took some sockets and bulbs. I put them in and they worked. I reset my maint reqd light, cleared engine codes (light did not come back), but my TCS, ABS, and SRS light remained on. I have a scan tool, not dealer level, and I had no codes. Lights were still on. Not sure what to chase down. Do I chase the wheel speed sensor or a wiring issue? FYI There was some bulb sockets that were different color. Some were blue the others were black. Didn't pay much attention to it because they all said v-2 on it and it didn't specify colors.
Does the ABS work? Does cruise control work? that will tell if the speed sensors are ok
try a parts store (except in California) they will use their code reader for free~!
It might be better than yours...
reminder that codes are clues = not a diagnosis in themselves
Cruise control works perfectly. Just tried it today. I will go to a parts store and see if they can pull codes and yes I never change parts based on codes. It just leads me in the right direction
These are the codes I got P0401. Exhaust gas recirculation flow insufficient detected (check engine light on again)
also code 9-2 Internal malfunction of the power supply for the SRS.
No abs/tcs codes.
Jump pins 4 & 9 on the OBDII port and turn ignition to ON and see if the lights blink. A consumer code reader won't read ABS or TCS codes from our cars. Not sure if O'Reilly's will or not. Good luck!
Sound like you need to clean your EGR ports.
I would do the intake manifold removal and clean the egr system from one end to the other! under 2 hours diy at casual pace with breaks, need 3 cans carb cleaner and a wire coat hanger (no kidding) to ream the main egr passage thru the `internal` length of intake manifold passage and port (single egr to cylinder port to clean on 99- should have been done once under a recall many years ago)
Service /clean IACV idle air control valve= built into bottom of Throttle body- it all comes off the engine with the intake manifold as a unit
need to both those jobs approx every 75kmiles to stay ahead of clogging issue- especially 99s!
Was this car a totaled/salvage vehicle? evidence of airbag deployment?
thatguy2 (12-21-2015)
did you try the ABS action? if thats working the speed sensors are good!!
Do you have a diagram or how do i know which ports to jump on the diagnostic connector?
SRS 9-2: "Internal failure of the SRS unit. If intermittent, it could mean internal failure of the power supply (VB line). NOTE: Before troubleshooting DTC 9-1 or 9-2, check the battery/system voltage. If the voltage is low, repair the charging system before troubleshooting the SRS"
ABS 11: Right front wheel sensor (open/short to body ground/short to power)
ABS 61: Low ignition voltage
ABS 81: CPU diagnosis, ROM/RAM diagnosis
TCS 31: Engine retard command (PFINH) signal
TCS 34: Reference voltage (VREF) signal
TCS 35: (I don't see this listed in the manual)
TCS 36: Throttle position sensor output (THLOUT) signal
FYI: For all of the TCS codes, the manual says to diagnose the ABS first if the ABS indicator is on. Otherwise, each of the TCS codes involves checking continuity for the lines specified through the wiring harness connector.
I would think that best case, you have some kind of battery and/or charging system problem causing all of this. Hopefully there is not a wiring issue. I would be inclined to think wiring issue if not for 9-2, ABS 61, and ABS 81 possibly pointing toward voltage issues. I would start there. Good luck! Keep us updated.
Here's what I could find from the service manual:
if the car was repaired under insurance- there is a PUBLIC record you can access with the info
All the needed warning bulbs removed from dash and odd SRS problems...
and you say there are no signs it had airbag deployment...really?
wanna bet the steering wheel airbag is nothing but old newspapers and a dirty tennis shoe?
Ck the one speed sensor the code says- wire damage is common to the front ones
A poorly performed brake job can mess up the wire! or rust- corrosion
odd thought: ck the ground wire from battery to body, it likes to come loose INSIDE the crimp connector = where it attaches to body- under battery tray
That will drive you nuts tracking down!
I also had the battery load tested. Tested good but it was on its last legs. 1/4 life left. Battery was about 12.3V before I tested the charging system
so your alternator is putting out fine... but the battery cannot hold the charge due to weak cell(s)?
Is that what you mean= on its last legs--1/4 life left?
Using the starter, or cranking load is what will show a weak cell- more than a standard quick load test,
the full draw of amps for the engine to start
Also a bad starter will draw more than the usual amount of amps
note on CCA or battery Cold Cranking Amps- the number everyone quotes on battery strength=
is the actual tested output after the battery sits at 32 degrees F for 8 hours = COLD, then is tested at starter draw amperage
Cold is batteries enemy. On a normal warm day/night that same battery has more amps than is listed on the label
funky/intermittent voltage from ground problem, or wandering voltage due to battery condition, can cause False Codes
ck out the ground wire base/mount to frame I mentioned before
Yehokhanan Jackson
1G TL (1996-1998)
11-27-2015 10:48 PM
