99 tl transmission issues HELP
Old 03-20-2014, 04:25 PM
9th Gear
99slammedTL's Avatar
I have a 99 tl. I'm having transmission problems(nothing new lol) the car when put into any gear d4 reverse etc will not engage u have to rev the car till about 2k then it will engage the gear and take off like it should does not slip while driving at all just that problem when taking off any ideas?
Old 03-20-2014, 04:33 PM
3.2TLc's Avatar
Perhaps the tranny's gear range selector is off a tad.
Does the indicator lamp show the gear selected when shifting into it ?
Old 03-20-2014, 04:34 PM
9th Gear
Yea it does even if I put it sport mode were it shows the gear it still acts the same way. How would I check it the gear range selector is off???
Old 03-20-2014, 05:22 PM
9th Gear
Is there a way to adjust it or see if it's off? I love the car but that's super annoying especially in traffic.
Old 03-20-2014, 05:26 PM
Mr.Helpful Diagram
ErickUa5's Avatar
Had a similar issue with an Accord ended up replacing the transmission.
The cause was, the owner never changed the ATF.
Have you tried changing the transmission fluid ?
Old 03-20-2014, 06:40 PM
9th Gear
No I haven't I just recently got the car but I checked the oil and it looks new it's not dirty or smells burnt. Would I be better off getting another 4speed tranny off a scrap car or rebuilt the one I have?
Old 03-20-2014, 07:37 PM
Mr.Helpful Diagram
ErickUa5's Avatar
Thats strange, either it was changed before the sale or the cooler is clogged.
Yes preferably one with low mileage and make sure its from a 99 TL not Accord or 2000 and up TL to avoid headaches.
Old 03-20-2014, 07:39 PM
Mr.Helpful Diagram
ErickUa5's Avatar
Forgot to ask what was the level ? was it between the dots, the engine must be warm and off to check the level.
Old 03-20-2014, 08:06 PM
9th Gear
Ok what would be good low mileage 100k and under? And yes I checked it just like that and it was right before the top dot.
Old 03-20-2014, 09:29 PM
Mr.Helpful Diagram
ErickUa5's Avatar
As low as possible and check the fluid condition. 100k is fine as long as the fluid is in good condition.
Old 03-20-2014, 09:50 PM
9th Gear
The guy up top mentioned something about a gear range selector or something maybe being off is there a way to check or adjust it?
Old 03-20-2014, 10:33 PM
Mr.Helpful Diagram
ErickUa5's Avatar
Yes its by the drivers side wheel well on the transmission it has a black metal cover.
If that doesn't solve it then it may be a clogged transmission cooler, The way I test it is to loop the cooler hose on the transmission and try to see if the problem persists, If it doesn't then the cooler is restricted and needs cleaning or the whole radiator needs replacing.
After the test put everything back to the way it was.
Old 03-21-2014, 03:21 PM
9th Gear
How do I adjust the gear thing? Or do I have to change it and I will check the cooler also can't hurt to try better than nothing
Old 03-21-2014, 05:21 PM
3.2TLc's Avatar
Remove the gear position switch's cover plate and set the switch to the "N" position.
The switch will "click" when it's in the correct Neutral position setting on the switch's control shaft.
Keep the switch assembly from moving while tightening up the retaining bolts.
Recheck the dash indicator for gear selected and make sure that the motor won't start in any gear other than "P" or "N". Also check the rear back-up lights when "R" is selected.
Old 03-21-2014, 05:40 PM
9th Gear
Do I do this with the car in neutral or park? Is there maybe a DIY that I can look at so I won't get lost
Old 03-22-2014, 06:50 AM
3.2TLc's Avatar
It's best to have the tranny in Neutral when attempting to adjust or replace the switch.
Old 03-22-2014, 09:35 AM
9th Gear
Ok thanks
mada51589
05-03-2022 08:54 PM
pstomps
02-20-2017 03:29 AM
carz0159
09-20-2015 06:11 PM
JDMVP
1G TL (1996-1998)
09-17-2015 06:14 PM
Quick Reply: 99 tl transmission issues HELP
