'99 TL engine J32a1 swap for 2000-03 J32a1 - possible?
Old 10-21-2011, 03:43 PM
8th Gear
narkotsky666's Avatar
Exclamation '99 TL engine J32a1 swap for 2000-03 J32a1 - possible?
Hi,
Searched all around the forum but found no information regarding this.
Basically I have to replace my '99 TL J32a1 engine and although technically it is the same engine in 2000-03 TL computer tells a different story. Also availability of straight '99 J32a1 is much worse then for 2000-03 engines. Now is the question? - did anyone do it? Took for example J32a1 from '03 TL and put into '99 TL? Will tranny fit? Will PCM work? etc etc - any information is greatly appreciated - engine is dead atm
Old 10-21-2011, 04:42 PM
Always Working In
my.daily'tl''s Avatar
Its been done before. Look around. FYI 99 engine is different from 00-03.
Millenium Falcon (02-06-2022)
Old 10-21-2011, 06:38 PM
8th Gear
As I said...
I looked around - couldn't find anyone who's done this. Saw threads going from J32a1 to J32a2 etc.
Old 10-21-2011, 07:40 PM
Tomb Acura's Avatar
Give up. Get a newer car. The rest of the thing is past it's usable life..
Old 10-21-2011, 07:42 PM
ParaSurfer1979's Avatar
May i ask why youre looking at the newer j32?
Old 10-21-2011, 07:50 PM
2000 acura tl FPR
assclown's Avatar
What are you smoking?
Originally Posted by narkotsky666
Hi,
I don't know much about the 99, I have a 2000 and swapped a J32a2 in.
I don't think anyone has done a 99 a1 to a 00-03 a1, think everyone has gone a2. But I understand you want to do something that's probably just plug and play. The tranny will definitely fit, the question is whether your pcm will do it. I know the 99's had different intake manifold but that's all I can think of engine wise. So I can't answer that question for you.
I got from the original post that he was asking because the j32a1 from the 2000-2003 models are easier to find and probably cheaper. 99 not so much.
narkotsky666 (10-21-2011)
Old 10-21-2011, 08:09 PM
8th Gear
Exactly
1. J32a1 from 99 are hard to find and they have over 100k on them. I have couple J32a1 from 00-03 range that are about 500$ in New England and have less then 50k miles. And I'm trying to do as less labor as possible.
2. My car basically not so old Has a new radiator, wheel & tires, Eibach suspension lowering kit & antiroll bars, tranny been replaced, disk rotors and brakes etc all less then a year old. So I'm not sure I wanna just trash it - rather keep it.
Old 10-21-2011, 08:34 PM
2000 acura tl FPR
assclown's Avatar
I understand where you come from. I wouldn't trash the car until you either total it or the transmission goes. Fsttyms1 has over 400,000 miles on his chassis.... he's taken good care of his car and changed power trains, but the car as a whole has been good to him.
Old 10-22-2011, 01:36 AM
Always Working In
Exactly.
The 99 was a j32a1 engine w/4speed and 00-03 came from factory with j32a2 w/5speed. More of the latter are available being they were produced 4 years to one. Yes they will swap. The engine and some sensors are different. I dont think anyones done 00-03 j32a1 swap. Its usually vice versa.
Old 10-22-2011, 01:57 AM
Why not just rebuild your motor with Hi compression pistons from 04-08 3.2 tl and RL cams?
Old 10-22-2011, 08:40 AM
8th Gear
The engine has 286k on it and #6 ignition plug blew out of the hole. So I rather replaced it with 'like' low mileage one.
Old 10-22-2011, 08:43 AM
8th Gear
99 came with J32a1 / 4 speed and 00-03 came with somewhat modified J32a1/5 speed. 00-03 also had J32a2 in type S. So if I can do drop replace with minimal labor for 03 J32a1 it's a winner for me.
Old 10-24-2011, 06:27 AM
8th Gear
Anyone? looks like no one done this one
Old 10-24-2011, 08:49 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
The motor is essentially the exact same (J32A1). The intake and fuel rail/ injectors are the main thing thats different. Id imagine every thing would be 100% plug and play
Old 10-24-2011, 09:14 AM
So I guess you answered my question about if 99 used coil packs or not. Why are u (OP) just calling Acura with these questions since you're not recieving much clarity in your thread.
Old 10-24-2011, 10:34 AM
8th Gear
Ordered J32a1 from 03 car - will post updates here on how it goes...
Old 10-24-2011, 10:58 AM
2000 acura tl FPR
assclown's Avatar
99 uses coil packs
Old 10-29-2011, 12:30 PM
johnny14's Avatar
Hi,
OP......depends on how much money you want to spend on it. There is alot of things that are completely different from 99-01 to 02-03 like dash wiring, engine wiring, sensors, etc. Can it be done. YES. Take it from me who went from a 99 Base to a 03 Type-S. Was it challenging. Hell YES! It may be easier to go from a Base to a Base model but there is still going to be some work involved.
Before jumping into it ask yourself how much money you want to spend on it. If money isnt an option and your wanting to do it because you like the car and dont want to sell it, for a challenge than I say hell with it and do it.
Hope this helps!
Old 10-29-2011, 12:51 PM
fsttyms1's Avatar
Hope this helps!
There is almost zero difference between base and base engines. There wont be rewiring or anything. Anything that is different he can pull off his old motor and put it on the new.
narkotsky666 (10-29-2011)
Old 10-29-2011, 05:54 PM
8th Gear
That is exactly my hope Well my mechanic will tell me if there are any specific additional things I will need this coming week.
Old 10-30-2011, 12:21 PM
johnny14's Avatar
Thanks for claring that up. So it appears to be alot easier going from base to base. So the wiring for the transmission are identical as well? Because the 99 is 4 speed as the newer ones are 5 speed so there has to be some differences in sensors, solinoids, fuse box, ecu, etc wouldn't there? Now if he was going from 99 to 01 its pretty identical but from going to 02 to 03 from a 99 is pretty different. ????
I've never played with the base to base so I'm not sure what all is involved but from base to type-s it's a challenging task. Anyways OP good luck with everything!
Old 10-30-2011, 12:35 PM
fsttyms1's Avatar
The op isnt changing the trans, just the motor. Motors have nothing to do with the trans wiring.
Old 10-31-2011, 09:38 AM
johnny14's Avatar
OH well than yes engine should mount right up with no issues base to base!
Old 11-08-2011, 03:58 PM
99 TLS6 08 TL
timberland73's Avatar
How big of a deal is it to go from base 99 to type-s 02-03? I'm thinking about doing this. No 6 speed tranny as I already have an 03 CLS6 and I just got the tranny replaced in the 99 TL almost a year ago.
Nathan Allan
07-01-2023 06:33 AM
dirtyspitshine
01-03-2023 08:23 PM
LECKEY73
02-22-2016 01:32 PM
justin7779
12-25-2015 10:33 PM
02tljj
09-11-2015 12:37 PM
Quick Reply: '99 TL engine J32a1 swap for 2000-03 J32a1 - possible?
