'99 TL Drag times/dyno #s
Wondering who here has run a '99 TL at the strip and what your times are. My best time running in auto mode is a 16.8 @ 83mph. This was 5800' above sea level. Hp and torque numbers are in my sig, I will have the dyno chart up later today or tomorrow. Also if you could list your mods. Thanks!
My mods right now include:
Stone Racing Headers
AEM CAI
Power Steering overdrive pulley
Car Sound High-flow Cat
When car was last run/dyno'd it had:
OBX headers
AEM CAI
Car Sound High-flow cat
AEM CAI
OBX headers
AEM CAI
Originally Posted by Got_3.2?
is 16.8 good?
That seems way off man.. I don't know if it's because of the altitude or your 4 gears... A 00 TL-P is capable of running 15.3 without any mods. A 02 TL-S can easily run 14.7 stock.
Originally Posted by Pure Adrenaline
With those mods, you should be running a little bit quicker than 16.8.
dans99tl
188 WHP
186 TQ
My TL:
188.8 WHP
185.9 TQ
And we have similar mods (we both have Stone Racing Headers).
I believe the dyno shows "corrected" numbers which accounts for barametric pressure etc. So it is not totally accurate of what my car really makes at altitude.
Patrick, ever run your car?
Originally Posted by patrick
Nope I haven't. But you make a good point. My dyno is "corrected" but at sea level. So I can assume that your TL will make a few ponies more at sea level with the mods that you have.
I got the Stone headers for free.... and the obx ones were dinged on the bottom from the previous owner, so I said what the hell. Really pretty much the same if you look at them side by side. The stone headers are ported on the inside, so they probably flow a little better, the O2 bung is in a slightly different spot, but other than than, they look exactly the same.
so does anyone want to cough up their times in a '99? Lots of talk, no numbers though, everyone always says your car SHOULD run ..... but I don't see anyone elses track times...
What I meant was the corrected #'s are what my car would make at sea level. It makes less than that at altitude.
AEM CAI
OBX headers
AEM CAI
AEM CAI
OBX headers
AEM CAI
i have an 01 tl with magnaflow straight pipe exhaust, and aem short ram intake. i ran a 15.3
Man I was hoping that there are some more '99 TL people out there that have raced their cars...
chuckstl, what altitude do run at?
Damn 15.3 is low for I/H/E/P on a 00-01 TL... They should do 15.2 stock according to car-stats :
http://www.car-stats.com/stats/shows...tsgivenid.aspx
The TL-S is running 14.8 1/4 and 6.2 0-60 which is definetly right. Check out the TL-S here :
I recommend gate shifting even though it's bad for your tranny if you do it too much.. You'll definetly feel the difference and see lower times.
i
Originally Posted by Tunaboy
whp jackass 225 from the crank I pity the foo
Smitty's Moral Police
According to Comptech '99TL stock makes 164.8HP/162.4TQ, and with H/E it makes 175.9HP/165.1TQ, so the your intakes must be synergistic with the H/E . Or they use a different dyno method, shrug.
http://www.comptechusa.com/images/dyno/1999TLplot.pdf
I have my dyno graph, but can't seem to open the file for some reason, I will keep working on it and get it up as soon as I get the problem figured out.
Altitude, barometric pressure, humidity, temp, etc.
These can all have very large impacts on how the car runs.
Nice find, I think they must use something other than a Dynojet type dyno to test their vehicles, I don't see my generic headers and AEM giving me that much more than the Comptech parts. If they do use a Dynojet, then damn, the stock TL-P doesn't make too much power.
Comptech's dyno with H/E is a good baseline for us (for comparison), as we can see what kind of gains we have over Comptech's when we do our mods.
Ok, finally got my dyno chart in the correct format. It will be posted tomorrow unless someone wants to host it for me. I stand corrected, my car makes 188hp, and 184 tq, not 186 like I remember for some reason...
Patrick, I am plenty a seasoned racer, I have been racing avidly for about 5 years and probably have over 500 passes in my CRX. The TL on the other hand was simply at the track as Sub car for the class I race in while the CRX was down. All runs thus far have been run only in Auto mode since I am a bracket racer and consistency is key. I'm fairly certain that the car is capable of running at least a couple tenths quicker with the sport shift, but again bracket racing is about consistency, not quickness.
Your reaction time has NO effect on your E.T. Your E.T. does not start until you have broken the beams, so you could in theory have a 15 second reaction time, and still run a 15 second E.T.
An ET of 16.8 @ 5800' = a 15.5 at sea level.
For 5,800' multiply your ET by .9276
16.8 *.9276 = 15.58
A Trap Speed of 83 MPH @ 58'' = 89.22 @ sea level.
For 5,800' multiply your MPH by 1.075
83 * 1.075 = 89.22.
What was your 60' time? A trap speed of 89 MPH seems about right for 188 whp.
16.8 *.9276 = 15.58
83 * 1.075 = 89.22.
Thx for the info. I learn something new. BTW, I was not implying anything about your driving skills. As I have never done any races at the track, I assumed (incorrectly) that reaction time was essential.
Here is my dyno graph for those who want to see it.
16.8 *.9276 = 15.58
83 * 1.075 = 89.22.
16.8 *.9276 = 15.58
83 * 1.075 = 89.22.
BTW how/where did you come up with the calculation to convert the E.T. and mph?
@ slide or die @
this might help...i have 99 also...
i didnt go to the track but i did run with some Beltronics thing my friend has...with all my mods, if i remember correctly it was either 14.6 or 16.4 (prob 14.6s.). I ran at like +-2ft above sea leve (FL) in mid 70s*F (60%+humidity). From a Complete stop => power break + SS no AC, radio, Nav off, lights, etc (all off) like 3/4tank and i didnt have mufflers (took off y-pipe and mufflers)
It should be getting cold again here i'll run again and show times.
When ^^ in Engine mods:
Obx SS headers
Injen CAI
UR crank
Iridium plugs
Vafc
no muffler
Me driving (20hp)
Hope this sheds some light.
*yep, it was loud.
Obx SS headers
Injen CAI
UR crank
Iridium plugs
Vafc
no muffler
Me driving (20hp)
*yep, it was loud.
60' times varied, but 2.5 is the best the car has done. This is horrible, and I'm not really sure why it's as high as it is. Normally the car pulls a 2.6 60'.
Your 60's are horrible and that is the main thing hurting your time. I have a CL-S and my best is a 2.0. I regularly run 2.1s now. You should be able to manage a 2.2 no problem. All else equal, by droping .1 from a 60' you should drop .2 of your ET. So by going from a 2.6 to a 2.2 you'd pick up .8 on your ET. Thus, you'd run a 14.7 at sea level. Not bad for a TL-P.
The formula is the standard from NHRA.
On a good day I get 2.1 or occasionally a 2.0 out of my CRX, but it has WAY more power and drag radials.
With the TL, the only thing I do is step on the gas to load up the torque converter as much as it will, then release the brake when the last yellow lights up.
Any pointers will be much appreciated as I normally race a manual, so launching the auto is totally foriegn to me.
