99 3.2 tl Catalytic converter/ EGR
Old 09-27-2011, 06:21 PM
everton's Avatar
Hello, I have a 99 3.2 TL with 205K. I love the car as it still performs well. I need to get an inspection except I have a CEL. The codes indicate an O-2 sensor and a problem with the cat. I am told, and have read that the problem is with the EGR port and all i have to do ias to clean it. I would like to take care of this myself in order to save a little money. I dont want to spend too much on a car with over 200k miles on it. Problem is, I have no idea where to start or what to do. Any help would be appreciated.
Thanks,
Old 09-27-2011, 06:29 PM
Avant Garde Wheels
jjashaa's Avatar
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-thermoblok-spacers-install-egr-cleaning-615644/
Old 09-28-2011, 10:34 AM
Boomer SOONER
ou sig's Avatar
you could also unhook the battery to clear the code before you go in for the inspection. then you can clean out the EGR port, intake manafold and throttle body later.
PM me if you have any specific questions about this - I have done it 4 or 5 times on my car over the past 8 years
everton (10-08-2011)
Old 09-28-2011, 10:27 PM
-Arsenic-
02type-s's Avatar
If you need a new cat, heres for if you live in any state but cali -
http://www.etrailer.com/Catalytic-Co...w/MF27402.html
I work for etrailer, they are legit
Old 09-29-2011, 10:43 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
muffler shops will test the cat for you- usually free
there is an electrical test for the O2 sensors but at this mileage I would replace the front sensor for sure
be aware the rear sensor- after cat- tells if the cat is working right
so you may have bad O2 sensors and a good cat
Does the car smell lean (eye buring tart smell) or rich at the tailpipes?
what codes exactly did you find?
does your state do smog test, or code reads or just a pure visual?
Old 09-29-2011, 12:22 PM
myron's Avatar
and this is for a 2G TL? but when you put in 1999 Acura there is only an option for an integra
Old 09-29-2011, 01:43 PM
2003 TL
webmastir's Avatar
http://www.youtube.com/watch?v=HRp6RWZ1egM
That's a howto on '99 EGR. Torque is necessary when securing the bolts on the IM. Don't forget that part.
Old 09-29-2011, 05:54 PM
-Arsenic-
02type-s's Avatar
That part number is for a 99 TL
mlody
12-04-2019 02:11 PM
Pham Alvan
03-16-2016 09:17 AM
fifer16
1G RL (1996-2004)
10-05-2015 10:12 AM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
Rcelestino93
09-23-2015 10:01 PM
Quick Reply: 99 3.2 tl Catalytic converter/ EGR
