97 3.2TL no crank after gasket change
Old 04-17-2014, 12:21 AM
D.Boss's Avatar
i replaced the oilfilter housing gasket and goto start the car... nothing. only wires that were touched where neg batt cable, oil press sensor wire, and the vtec wire were disconnected (and all reconnected)
with the key in position II i have dash lights as normal, headlights, blinkers, radio, etc all normal. but when i turn the key to start the car i get a light click of a relay under the dash somewhere, but ZERO from the starter...
i have checked the starter wire while cranking and get 0 volts at the S terminal (small starter wire)and have batt voltage at the B+ wire ...
I DO get batt voltage at the ignition switch start wire (by the steering wheel) while trying to start the car...
if i run batt voltage via jumper wire to the S terminal the starter fires right up and the car starts just fine (key already in pos II)
i have looked everywhere for a wiring diagram for this circuit and cant find one...
what is between the ign switch and the starter solenoid? any relays or fuses?
i know its not a strait shot from the column to the starter as the wire color and gauge are different.
to recap
batt good
cables good clean and tight'
everything has power as needed
green vats light is OFF
ign switch tests good
only thing i can think of is neutral safety switch on the trans BUT it has same symptoms in neutral as in park
any ideas?
Old 04-17-2014, 12:42 AM
D.Boss's Avatar
not to 2x post... cant find the edit post button.. it is NOT a 1997... it is a 2000 TL 3.2L... its late and my brain is mush after messing with this car all day (13 hrs)
saberlove
03-11-2021 09:29 AM
Laoch
1G RL (1996-2004)
10-02-2015 03:27 PM
ghuns
09-16-2015 04:26 PM
Aleax
09-11-2015 11:31 AM
michaellong77
1G CL Problems & Fixes
09-11-2015 12:54 AM
Quick Reply: 97 3.2TL no crank after gasket change
