6 speed conversion, 2nd problem 9/2/17
Old 04-04-2006, 10:41 PM
  #321
318whp/289wtq @ 6psi
blk2001tlon19s's Avatar
Originally Posted by blokhead
Kris, don't forget you'll have a higher redline with the type-s ecu/engine, so the tach won't be right (minor issue..) Will the yocal acura dealer flash your old key/ignition cylinder to the new ecu? Great job, I might have to head to the northwoods this summer just to check out your ride... unless mine falls under the knife also. Now that I have the ws-6 to rip around in, the tl has become a garage queen and it is getting more and more tempting to install a 6 speed, then I will have 2 6 speeds . later
sorry, you mean 3 of them.
Old 04-05-2006, 08:44 AM
  #322
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
I think he meant he'd have 2 6MTs.. the WS-6 and the TL.
Kris is supposedly going to install CL-S6 gauges so it won't be an issue.
Old 04-05-2006, 08:51 AM
  #323
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Im going to get the gauges, i just havent done that yet. I want to see if my cluster will work (and just buy the faces) or if i have to buy the whole cluster
Originally Posted by ThinJim
What a project! I've been following your progress and your on top of it all the way. BTW, why didn't you pressure clean everything before the engine install? Are you going to put headers on it too? Good work!
Because i didnt install it for good yet. That was just put in to test to see if it fit under the hood. I pulled it back out last night and actually cleaned it up a little. Headers? not right away. I may try to see if i can get the DC headers to fit sometime this summer Im not terribly concerned about adding more HP right now as i am getting it to work properly
Old 04-05-2006, 06:42 PM
  #324
fsttyms1's Avatar
Just ran into a small snag. I need to figure out what harness i have to order now. I took my ecu out today and the plug isnt the same as the one on the new 6 speed ecu. Im assuming its the INSTRUMENT wireharnes?? I see there are 2 harness to buy (dash and inst) i need to figure out what one. (conector E) and judging by some of the pin outs im thinking its the inst?? any ideas??
under 2003 CL 6speed wire harnes
http://www.acuraautomotiveparts.org/...prddisplay.jsp
Old 04-05-2006, 10:06 PM
  #325
I agree with you kris. I still haven't figured out what wire is for the mph signal but then again, I havne't looked at my helm manuals yet.
Old 04-05-2006, 10:21 PM
  #326
fsttyms1's Avatar
Looks like on our gauges its blue/white conector C. PCM-A #9 for the auto ecu blue/white
Old 04-05-2006, 11:32 PM
  #327
yeah, I got that but where does the signal come from? The transmission or a sensor on the axles? That's the part I need to figure out since I won't be using the Cl-s like you.
Old 04-06-2006, 01:39 PM
  #328
fsttyms1's Avatar
Made some calls and it sounds like i need both. so i ordered both. if this thing isnt plug and play when im done nothing will be
Old 04-06-2006, 01:45 PM
  #329
lol
I'm going to try to put the cl-s 6 console in also. I mihgt try that since my car is currently disabled.
Old 04-06-2006, 03:13 PM
  #330
fsttyms1's Avatar
I feel like a kid in a candy store. UPS just delivered more goodies!
Got the shifter, clutch flywheel, shift cables, and an asortment of nuts and bolts
im not sure what ill do with the engine cover since it probably wont fit with out hood midification??
Old 04-06-2006, 03:30 PM
  #331
nice
Old 04-06-2006, 04:03 PM
  #332
Yes it is!
Deity711's Avatar
What kind of hood mod would you do? I'd think a power dome doesn't really fit with our car. Are you thinking a little hump like on the 2nd gen Eclipse? Faux hood scoop?
Old 04-06-2006, 04:07 PM
  #333
ITL
I do my own work.
ITL's Avatar
why do you even need a hood?
Old 04-06-2006, 04:36 PM
  #334
Registered User
Blazin_TL's Avatar
Old 04-06-2006, 04:45 PM
  #335
On the way!
fla-tls's Avatar
I'm thinking you might try a modified Firebird Trans Am hood from the late 70's. I want to see that "6.6 litre" on the side!
P.S. I just checked the specs on those old cars... 400 cubic inches - a whopping 180 hp... Now THAT'S american muscle... (NOT!)
Old 04-06-2006, 05:08 PM
  #336
Future JDM Whore
Da_iLLeZt_TL973's Avatar
dam kris you and the UPS man are gonna be best friends pretty soon lol ......goodluck with the rest of the project i cant wait to see it done its gives hope to alot of TL owners who might try to tackle this in the future like myself once the car is dead for good lol
Old 04-06-2006, 05:22 PM
  #337
fsttyms1's Avatar
I would just cut along the alread there hood lines and just slightly raise it. It wouldnt be a "hood bulge" like most are thinking, like you would see on a old car.
Old 04-06-2006, 05:24 PM
  #338
fsttyms1's Avatar
Well duh.that right in the middle of the emissions crap. Chesk out the same specs 65-70 and i bet they will be ALOT higher. also look at the special options modles and 1/2 year models. they will be pushing 400hp
Old 04-06-2006, 05:29 PM
  #339
Someday, an RS6 Avant+
mrmako's Avatar
For fsttyms1
Your conversion looks good so far. If you need anything from here let me know (within reason, as big parts would cost alot to ship)
Old 04-06-2006, 05:38 PM
  #340
fsttyms1's Avatar
Cool! thanks.
Old 04-07-2006, 01:59 PM
  #341
fsttyms1's Avatar
Got teh flywheel mounted But i need a tool to install the pressure plate and clutch.
I cant believe no one makes a presure plate tool and clutch alignment tool i can buy or rent Guess ill have to make that this weekend
Old 04-07-2006, 03:02 PM
  #342
On the way!
fla-tls's Avatar
The clutch didn't come with the alignment tool? Every Luk clutch I buy has the tool in the box (stupid dealer clutches are not DIY friendly). If you lived closer, I'd let you pick out the right tool from my pegboard and borrow it. I have several Honda alignment tools, but don't know which one that would take. I tried looking it up on Mitchell and came up with nothing.
Old 04-07-2006, 03:39 PM
  #343
fsttyms1's Avatar
Yea teh one you buy thru the dealer (the only place you can get a clutch for teh stupid car) doesnt come with a clutch kit tool, because thats issued to the dealer. I have no idea what it looks like or if any ol honda one would work. I for the life of me i cant find a damn tool in the state.. Im pissed at honda for this kinda crap. Plus i have to fabricate a tool to compress the pressure plate too.
Old 04-07-2006, 04:22 PM
  #344
8th Gear
ss03tl's Avatar
someone may have asked this already, but will the 6sp manual tranny bolt up to a 2003 tl-p motor? i would love to keep my car, but really don't want to mess with the ECU or any of the hundreds of feet of wiring in these cars. i could accomplish the mechanics of the tranny swap easy enough. the extra power from the type S motor isn't so important to me.
Old 04-07-2006, 04:27 PM
  #345
fsttyms1's Avatar
It will bolt right up but you are going to run into having to trick the ECU somehow. I didnt feel like messing with trying to figure it out, but im sure it can be done.. The ecu in our car controls the AUTO tranny along with the engine. With the manual in there it wont know what to do.
Old 04-07-2006, 07:10 PM
  #346
It will work however it won't rev past 5000rpms or so because the ecu won't notice the car is in gear. You will probably either need to run a standalone ecu or cl-s 6 ecu for it to run properly.
Old 04-08-2006, 11:21 PM
  #347
6th Gear
jfeger's Avatar
Why mod the hood?
I guess I dont know the difference...and havent read the entire thread. But...why does the TL-s engine sit closer to the hood? Arent the cars the same body and chassis arrangmenet?
Old 04-09-2006, 12:44 AM
  #348
RickRoush03
RickRoush03's Avatar
wow bro, props to you on this journey!!! way more than i would have ever wanted to get into but i am glad it seems to be working out for ya.
Old 04-09-2006, 03:50 PM
  #349
WiLLs TypE S's Avatar
Definitely get a 6-speed ecu. But good luck..because those things will cost u an arm and aleg. Estimate..ranging from a thousand to two thousand. new. Your not going to get it used..unless its salvaged..and from what I hear...not too many CL-S 6-speeds were sold..so also good luck in finding one that's destroyed.
Old 04-09-2006, 03:51 PM
  #350
fsttyms1's Avatar
I got mine used for 200 bucks. and new they are 700
Old 04-09-2006, 03:52 PM
  #351
fsttyms1's Avatar
the TL-S motor sits higher due to taller intake manifold. The redesign on the TL in 02-03 is for the type-s motor. The hood sits higher to allow more clearance for that engine
Old 04-09-2006, 03:54 PM
  #352
That's great.. =) glad it worked out for ya. Because I know a 300zx 5-speed chip is 800 dollars...brand new...list price. But there's always ways around the system. I bought one used for 90 bucks. lol.
Old 04-09-2006, 07:34 PM
  #353
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Hey Kris,
Took some crude measurements and there is no way the TypeS intake manifold is gonna clear the 99-01 hood. If you look under the hood, you'll see that they pretty much cut around the shape of the IM to get it to fit nice and snug. Sucks for us.
Old 04-09-2006, 08:25 PM
  #354
could always put the tl-p intake manifold on there ..
Old 04-09-2006, 08:34 PM
  #355
mclarenf3387's Avatar
NSNEXT wants to fit the Type-S manifold on his car, thats why he is interested in the fitament. But I don't see the issue as Kris already said it would fit. Although no one knows if there is enough wiggle room in there for the engine to move a little.
Old 04-09-2006, 08:35 PM
  #356
fsttyms1's Avatar
Originally Posted by NSXNEXT
Hey Kris,
Did you see this post?
https://acurazine.com/forums/showpos...&postcount=293
Old 04-09-2006, 08:39 PM
  #357
fsttyms1's Avatar
I covered the top of the mani with shaving cream about 1 inch thick and after i closed the hood and only about 1/4 to 3/8 inch got smushed out/donw at its closest point. Like i said, im not sure how much the motor moves but it kinda looks like it will work. Guess ill find out first time i floor it wether it hits or not??
Old 04-09-2006, 08:43 PM
  #358
NSXNEXT's Avatar
I sure hope it fits. I'm gonna go back and sit in the corner.
Old 04-09-2006, 08:45 PM
  #359
fsttyms1's Avatar
If your going to sit in the corner you better have one of those cone dunce caps on j/k
Old 04-09-2006, 09:04 PM
  #360
NSXNEXT's Avatar
Did you at least test fit the IM on your old engine?
Quick Reply: 6 speed conversion, 2nd problem 9/2/17
