6 speed conversion, 2nd problem 9/2/17
Old 11-29-2014, 09:17 PM
  #1121
3.7L Nitrous Breathing CL
richardparker's Avatar
Originally Posted by fsttyms1
i need to figure out what the harnes conectors are on the drivers side. ill count the pins tomorrow but they are teh upper and lower dash harness. they arent conected to any thing. there are like 5 of them. Also is the cruise control switch different on the CLs??
Where did the 5 connectors end up going ?
I just installed my upper and lower dash harnesses today and I have a handful of extra connetors on the lower drivers side.
Old 09-07-2017, 08:07 AM
  #1122
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Welp, shift cable decided it was going to snap. Luckily was only a mile or so from home and the 3.7 has enough tq to get the car moving in 4th from a stop light easily enough and able to lunk along to get it home. Time to locate a new one.
Old 09-12-2017, 01:51 PM
  #1123
Chojun's Avatar
^ Not sure if anyone picked up on the significance that he's able to limp home stuck in 4th.
Old 09-12-2017, 02:07 PM
  #1124
3.5 psi
gnuts's Avatar
any signs of why it snapped? I sometimes stay in 3rd and do a half stop at a stop sign but 4th would be funny.
Old 09-12-2017, 05:07 PM
  #1125
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
If the 3.7 can wheel spin to 2nd in my 4500lb MDX (With SH-AWD disabled) It does not surprise me it can limp in 4th in the lighter TL...
Old 09-25-2017, 01:07 PM
  #1126
3rd Gear
RAT1964's Avatar
You had another thread from 2016 regarding code p0386.
Looked like you replaced everything but still had the code.
How did that work out in the end?
I spun a rod bearing on my '03 Cl-S 6mt, dropped in a donor engine from TL-S and have the same code.
Old 09-26-2017, 02:28 PM
  #1127
Received 1,735 Likes on 1,391 Posts
That code, P0386, is for the crankshaft position sensor B which is located on the 6-speed transmission bell housing.
If you decide to replace it in pursuit of trying to get rid of the P0386 code, you can find alternatives to the discontinued Acura part #37506-PGE-A12 on the thread below:
https://acurazine.com/forums/2g-cl-p...ilable-960248/
teh CL (10-09-2017)
Old 09-29-2017, 12:18 AM
  #1128
3rd Gear
RAT1964's Avatar
Much obliged for the alternative part numbers.
Cheers!
Old 10-15-2019, 08:54 PM
  #1129
Marque Pacheco's Avatar
What happened to the images in this thread?
Old 10-16-2019, 03:00 PM
  #1130
Arkady's Avatar
They were hosted somewhere that isn't around anymore, and as such are dead.
EE4Life
04-01-2024 09:42 AM
csmeance
1/2G MDX (2001-2013)
63
10-06-2018 05:13 PM
RYAN97812
06-08-2017 11:02 AM
JDMisWife
10-13-2016 10:23 AM
chupp
2G RDX Performance Parts & Modifications
10-08-2016 12:38 PM
Quick Reply: 6 speed conversion, 2nd problem 9/2/17
