3.5 conversion
is making xxx movies
3.5 conversion
Long story short I cracked my oil pan on the highway and had to drive a little further than I wanted to while the oil was dumping out of the car. Replaced oil pan and drove the car, seems like I need a new bottom end now. Considering just doing a 3.5 conversion while I have the chance.
Someone correct me if I'm wrong. But for the most part I just need mdx or odessy crank and then use rest of type s stuff ie. Rods, pistons, rings and type s heads? Stock j32 block? What about the computer? Would it adjust itself or would I need tuning?
Honestly don't wanna dump this $ into the car especially being this old. But at the same time I don't wanna junk the car because it's well taken care of, as of right now 101k all original miles. (Granted I cracked the oil pan and need a new bottom end) Interior is still perfect, probably could use a good waxing on paint but the car is in great condition. Pretty much it's whole life has been in a garage and barely driven.
Not sure if the ogs in 2nd gen community are even around anymore but figured it would sure clear up some questions I have
It will be cheaper just to buy the entire J35A3 engine and swap it in..
If you didn´t have a Type-S to begin with you don´t have the ECU to take advantage of the Tune and Higher Redline anyway so there is no need to get the Type-S Heads.
Can I just do mdx short block and add my heads and all the extras from my existing j32? Trying to at least make some more power while I have the chance
Latent car nut
Received 2,005 Likes
Have you confirmed the bolt pattern for the transmission between the J35 and your current J32 are the same?
Latent car nut
There were no 3.5L TL Type-S production models for 2G. Unless I'm in the wrong forum.
This thread is about J35A3:
- 2001-2002 Acura MDX
- 2004-2007 Saturn Vue also referred to as GM L66
Latent car nut
Stock mdx engine? Would buying the mdx motor with j32 Cams be comparable to the stock j32? Of course torque would be better with more displacement.
Power will not be comparable Stock v Stock but the Torque will make up for it BIG TIME.. You can also cut the block deck in order to raise compression and make power beyond the J32A2.
You can but you will have to fetch a used J35A3 block anyway (I do not know many junkyards that will sell you half an Engine) So this route is more challenging.
I also clearly stated a specific engine called J35 "A3" there is no typo there, Nobody say buy any Honda or Acura J35 and YOLO!
The only J35 that will fit has to have an "A3" in the code name as in: "J35A3" also known as 1G MDX Engine. It also has to come from the EARLY 1G MDX as they changed to the retarded Header-In-Head system in the bumped up engine from the MDX 2003 and up making the potential power making lower with the lack of Real Headers option.
More info:
The J35A3 uses exactly the same Block as the J32A2 (They even have the same part Number block) so to Answer your question.
YES the J35A3 is DIRECT BOLT ON to the Stock B7WA Transmission or AV6 Transmission or The 6 Speed Manual for the 2G TL/TL-S/CL/CL-S.
Latent car nut
Thanks, good to know.
This is a 2nd gen TL thread in a 2G gen TL forum... So the answers are specific to the 2G TL
More info:
More info:
Skirmich, all of that specific info. you listed above is excellent and horseshoez has been recently exposed to it in a very similar thread discussion on the 2G CL side, it's just not retained.
https://acurazine.com/forums/second-...advice-960284/
Perhaps he didn´t know the CL and TL are identical drivetrain wise.. Considering most of his info relies on the 3G TL and the 3G TL didn´t share with anything.
horseshoez (08-02-2017)
However, when there is clear discussion in regards to bolting a J35A3 to a 2G CL-S 6speed, which will take either a J32A2 from an auto trans TL-S or CL-S, with the modifications mentioned, as you know, paying attention to detail is important, just saying.
Unregistered Member
I would recommend getting a J35A3 and swapping in the cams. Sure you can swap the whole head and even machine the head for extra compression, but I think the swapping just the cams is very easy and you don't have to mess with the head gasket.
Latent car nut
Wow, you're really arrogant for being so ignorant.
If you take my comments in this thread in context you'll see I posed it as a cautionary question and not a statement of fact the two engines were not interchangeable.
Latent car nut
Yup, just as I figured, you can dish it out but you cannot take it. Time to grow a pair buddy.
Latent car nut
Really? Nope, not intended; I was simply trying to look out for the best interest of vip_inspire, I didn't want him to buy a motor which wouldn't bolt up. I learned both the J32 and J35 blocks were cast with different transmission interface patterns; thanks for the schooling.
The thing to know here is that "J35" does not equal EVERY 3.5L out there, The J35 has been around since 1999...
Engine code numbers are very important.. For example:
J35"A3" = MDX Engine
J35"A8" = RL/3G TL-S Engine
Both are 3.5L in displacement but they have very different Transmission bolt patterns.
There are also different heads used for the same block which also change the engine code number so for example:
J35"A3" has the same transmission bolt pattern thus the same block as the J35"A5" but.. The J35"A5" has those stupid Headers-On-Head system.
So they could bolt-on for the 2G TL transmission but the exhaust system will have to be severely modified.
Latent car nut
Unregistered Member
Yup, just as I figured. You like to give advice while knowing next to nothing. Hopefully you learned something, buddy.
Nope.. The 3G TL has updated transmission bolt patterns starting with the J32A3, The J35A5 while having the same retarded Headers-on-head system as the J35A8 will not bolt on to the transmission because it has the old transmission pattern of the J32A2 which shares the same block.
Latent car nut
Latent car nut
So for the sake of argument I assume I can bolt on j32 heads on the j35 block. I'm thinking type s heads will flow better than mdx/odessy heads. Someone correct me if I'm wrong.
As far as tuning is concerned what computer would I run with the 3.5 conversion and type s heads?
What computer would be ran using j35 with type s Cams?
If I was to just buy parts and rebuild the engine. All I would really need is the mdx/odyessy crank right? J32 pistons, rings, rods, and bearings?
IIRC someone says the Heads are actually the same on both engines the only thing that differentiate the J32A2 is the Camshaft which is more aggressive for Top End Power. So you could swap the Camshaft or the entire head if you please, The important thing is to run the J32A2 Camshafts.
The ECU you want to run is the Type-S ECU because of the extra oomp of the Camshafts it is tuned for Top End Power and the 7K RPM Refline.. It also has a more aggresive VTEC engagement.
As far as specific parts I dunno because most people running that setup do not bother by going single parts they usually buy the entire J35A3
