Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003)
Reload this Page >
2003 TLS -I have code 53-1 = ABS pump motor relay short, VSA, ABS, Exclamation lights
Notices
Old 05-31-2019, 11:42 AM
Registered Member
I just got my the recall done (second time) on my air bag inflator and on the way home, I hit a pot hole and immediately abs, vsa, and exclamation/triangle lights came on.
Ran a scan, it had 3 codes 53-1 = ABS pump motor relay short being one of them and cleared all 3. 53-1 immediately comes back and the others went away. Tested all wheel speed sensors with the scan tool live data feature and they're all working properly. I attempted to test the ABS pump with live data as well and all the device would show me a is a fluctuation of 3.9 to 4.2 volts on a graph, but the voltage did move if that means anything relating to functionality.
I will test abs with a hard stop later today but wanted to see if anyone has any advice to further troubleshoot this issue.
Knicee is offline
Old 05-31-2019, 08:41 PM
Registered Member
ABS Does work - I tried slamming on the brakes and felt pulsation and came to an immediate stop without skidding.
Knicee is offline
Jamus22
08-25-2018 01:53 PM
toannguyen93
07-26-2018 10:19 PM
jhumbo
10-08-2012 10:53 AM
smooth CL-in
Second Generation CL Discussion (2000-2003)
01-04-2008 11:53 AM
chaeric
11-01-2005 08:11 AM
Quick Reply: 2003 TLS -I have code 53-1 = ABS pump motor relay short, VSA, ABS, Exclamation lights
