Notices
2002 Acura TL Type S shaking and CEL flashing
Old 03-19-2019, 07:18 AM
New Member
Liked 0 Times in 0 Posts
Hello everyone! A few months ago I purchased a 2002 Acura TL Type S with 151,000 for a great price. Itís now at around 157,000 and Iím running into some problems now, I stopped at a gas station and when I turned my car back on, it was idling at around 400-500 rpm and was shaking, I gave it a couple revs and the shaking goes away at around 1,500 rpm and my check engine light flashes every few minutes. I was reading another thread about this problem. Today Iím doing spark plugs, cleaning up the intake manifold and EGR valve with some carb cleaner. If that doesnít work, imgoing to unplug a coil one at a time to see if the RPM drops, and whichever one doesnít drop the RPM, (Iím hoping itís just one) then I will replace that ignition coil. I will keep everyone updated, hopefully with good news!
Justin Limley is offline
Old 03-21-2019, 09:09 PM
New Member
Please do post if that fixes the problem. I am having the same issue with my 03 tl
crazyq29 is offline
Old 03-22-2019, 06:17 PM
Registered Member
I had a flashing CEL and rough idling at times.... Codes were returned as Random misfire .Turn out one of my coil pack was bad... Most of the time it's number 2 coil that the culprit on these cars.
Chiller2002TL is offline
Old 03-28-2019, 02:14 PM
Registered Member
Silencer_'s Avatar
Liked 7 Times in 7 Posts
Had the same problem on my 2000. It would shake and had a rough idle. It ran fine after I changed the spark plugs and coil pack.
Silencer_ is offline
Bhanu Kendall
Second Generation RDX (2013-2018)
07-17-2017 10:05 PM
xtraesc
11-21-2016 09:45 AM
bama boy
12-04-2009 09:31 AM
drummr8
Second Generation TL (1999-2003)
28
02-16-2009 05:04 PM
Quick Reply: 2002 Acura TL Type S shaking and CEL flashing
