2001 TL Driver Side Headlight / Low Beam takes a while to start
I have a 2001 TL. My driver side headlight / low beam is dimmer than the passenger side. It also occasionally takes a few minutes to start, so only the passenger side would be on. I replaced both with HID bulbs. They are roughly around the same color now. The problem with the driver side taking a few minutes to start persisted. Has anyone else had this issue and have suggestions?
Thanks!
Thanks!
Check out this thread: https://acurazine.com/forums/second-...roblem-781734/
Sounds like you might be dealing with a ballast issue, but I'd search for some other threads to get some more info first - since ballasts aren't exactly the cheapest things in the world.
User 12221 (01-25-2019)
Thanks! I suspected it might be a ballast problem as well. In the past two days, my driver side headlight has been working fine. Until it becomes a reoccurring issue, I will hold up on the fix.
hondeducation
12-22-2017 02:37 AM
Kevin17112
05-13-2017 04:49 PM
Blizzard
Integra
03-12-2010 01:10 PM
