2000 TL Won’t Go Into Reverse
All-I’m having some issues with my DD 2000 TL. Ive been having multiple issues for the past month. It all started with the P0780 code. Got the TCS light and flashing D5. I replaced the 3rd gear pressure switch. I then did a 3x3 trans flush using Honda trans fluid. Things were fine for a little while (20 miles) then got the TCS and flashing D5 again. I damn near overheated the engine on the way home from work. I cleaned the shift solenoids and cleared the codes. All the lights are off but I now have one slight problem. I can’t go into reverse. It’s like the car is in neutral. I also checked the coils and all are good. Can anyone help me out? I appreciate it!
Aw man...that really sucks. I was thinking that maybe the after market pressure switch may have cause the issue since after I replaced it is when I started having all the problems. It’s too old and too many miles on it for a new trans. Think it’s time to let it go. :*(
Do this. https://www.youtube.com/watch?v=Zbar...ature=youtu.be . There is a member of this forum who make this video and tread about it. It that do not work you need new tranny.
Here is tread https://acurazine.com/forums/2g-tl-p...-again-929434/ .
Thank you for the response! I followed his video and cleaned the solenoids. I did not, however, check it with a multimeter. I will do that as my last attempt. I drove it around today and got a different code: P0730 Incorrect Gear Ratio. It didn't necessarily feel like the gears were grinding but it was more so erratic shifting. If the solenoids are bad then I'll replace but I may be better of donating the car. I really don't want to
Yeah I got the same problem though I was just driving no problems everything was working fine go into a parking lot come back go and reverse it wouldn't go in reverse so I had to push the car out of a parking lot that was embarrassing.
lvlarkeo
09-16-2012 06:44 PM
bignoodleboi
1G CL Photograph Gallery
12-29-2003 05:24 PM
bignoodleboi
12-15-2003 11:02 AM
